date codes please help - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-01-2013, 08:10 PM Thread Starter
My car cars build date is 2 0f 64 so for a numbers matching motor the date code would have to A or B --4. Could it be a late 63 date? Would the heads and intake have to be the same?
Thank you for the help
remy30006 is offline
post #2 of 2 (permalink) Old 09-02-2013, 09:27 AM
gtoguy389's Avatar
The date codes on the engine and transmission can be as close as 10 days prior to the build date of the car, or as far apart as 6-8 weeks prior, generally speaking. It would be absolutely possible for you to have a late '63 or A '64 date codes. The heads and intake codes should be close, but not necessarily the same day as the block. I have thoroughly checked and verified my car, my intake and block were cast one day apart, (4-1/2 weeks before the build date of the car), and the heads were cast two weeks later. My transmission was built one week before the car, (verified by the vin stamped into the case.) It all depends on when the parts were supplied to the assembly line. Matching the date codes on the castings wasn't a big concern as they grabbed whatever they had available. As long as everything was cast within a time frame, and built within a reasonable time frame to the car, you'll be in good shape.
gtoguy389 is offline
When to worry about date codes AMT1379 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 08-20-2013 09:00 AM
TH 400 date codes??? OrbitOrange 1964-1974 Tempest, Lemans & GTO General Discussion 8 01-22-2012 03:27 PM
GTO Distributors Date Codes theamcguy 1964-1974 Tempest, Lemans & GTO General Discussion 5 06-16-2011 07:27 PM
Date Range? MichaelG 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-21-2010 05:49 AM
Build Date Rob Govoni 2004-2006 GTO General Discussion 1 10-23-2006 07:31 PM
