Deck filler - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-14-2018, 10:34 AM Thread Starter
Deck filler
Installing a new deck filler on a 66 tempest, is it common to weld in from the underside?
1966tempest is offline
post #2 of 4 (permalink) Old 09-14-2018, 09:00 PM
Deck filler and weld in? Sorry but I'm not sure what you're referring to. There's a material called Hard Blok that is essentially a type of concrete. It's put in the block water jackets, usually only up to the level of the casting plugs. Supposedly it adds rigidity and strength to the block.
Can you provide more detail?
post #3 of 4 (permalink) Old 09-15-2018, 04:39 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
If you lay in the trunk with a good light, looking up into the panel area you will get an idea of whats in-store in as far as weld points.
Lots of spot weld to be removed. Lots of online videos with good tips.
Cheers
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 4 (permalink) Old 09-25-2018, 10:15 PM
Quoted: 13 Post(s)
I am also close to installing my deck filler panel on my 67. When I removed the old one, there was a fiber mat underneath. I am assuming this is for insulation and to space between the panel and the underside structure.
I was able to remove it in one piece with very little damage and probably could reuse it.
I am wondering what others have done. Did you use a new Dynamat type product, reuse existing, find a replacement, or leave it out.
The original is pretty fragile and I am afraid it will start to deteriorate and fall through into the trunk. Needless to say, once I put this in, I wonít be able to change my mind.
The pad is about .10 inches thick, if that matters.
Any thoughts are appreciated.
Colorado67GTO is online now
1968 rear deck filler and package tray repair frankrp 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-14-2018 10:49 AM
Need deck lid filler panel for 65 GTO hardtop SlamminGears65Goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 01-01-2013 06:42 PM
65 Gto rear deck filler question ElMedioGringo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 08-13-2012 02:53 PM
66 rear deck filler question Logchain 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 12-25-2011 04:31 PM
rear deck filler panel tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-23-2011 07:46 AM
