Decoding this block - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-30-2017, 04:08 PM Thread Starter
Quoted: 9 Post(s)
Decoding this block
Hi -
I'm trying to figure out what block I have.... On the ledge, passenger side behind the last cylinder (under right side of distributor as sitting in drivers seat) I found the number 9790071. On the front of the block, I found stamped YC.
So after a ton of reading, I did a lookup here: Pontiac Hunters - Pontiac V8 Engine Codes
Best I can tell, it's a 400 block out of a 68 or 69 B-body. (See attached screen grab)
So what I'm left wondering, and what I hope someone here can chime in on:
- Do you agree with my assessment that it's a 68 or 69 B-Body based on the numbers and stamp I found?
- If it is indeed a 68 or 69 B-Body 400, is there any way to tell what car it came from?
Any input would be great - there's a TON of info out there, some conflicting and I'd love to figure out the history of this block.
Thanks!
Name:	Screen Shot 2017-06-30 at 5.08.09 PM.png
Bredfan is offline
post #2 of 5 (permalink) Old 06-30-2017, 05:44 PM
Welcome to the Forum. To narrow down what year, you're going to need to look back by the distrib hole & look at the alphanumeric date code. "071" 400 blocks wre indeed cast for both '68 & '69 model years of common 400 Pontiac blocks. The YC coded 400 was very common in '68 & '69 models, as it was the base 400 2bbl code for 400/auto Catalinas. YC or YE coded 400 2bl were also used in '69 Executives. Nearly all Catalina's & '69 Executives, had the 400 2bbl & matching T400 auto. Very very few of these entry level B series slipped out of the factory in '68 with the base 3spd manual 400 2bbl engine. The base engine for a '68 Bonneville is the 340 horse 400 4bbl with small valve ('68 model) 15 heads. The base engine for the '69 Bonneville was the YH coded 428.
Below is a link to Wallace Racings engine code list, it's 99% complete & correct. I surfed the Pontiac Hunters link you put up & noticed quite a few errors. The Pontiac Hunters list also does not list the cyl head(s) originally used on said engines by cyl head code. Hope this helps.
Wallace Racing - Engine Code Charts
post #3 of 5 (permalink) Old 07-01-2017, 02:33 PM Thread Starter
Quoted: 9 Post(s)
Great info - thank you!
So, here's what I have now...
- Number on drivers side of distributor is K157 - I have this as November 15, 1967
- Block number is 9790071, YC - that would be 1968 or 69
- Cylinder head is 15 - the "1" and "5" are separate, not positioned together
- Cylinder head has date stamp K217 - I have this as November 21, 1967
Since the date code on the block is late in 67 (Nov) and the date stamp on the head is also November, can I safely assume that the block and head have been together since birth and that they were originally in a 1968 full size?
Looks like a 290HP 2bbl from 1968... See attached from Wallace...
Thanks again!!
Name:	Screen Shot 2017-07-01 at 3.34.58 PM.png
Bredfan is offline
post #4 of 5 (permalink) Old 07-01-2017, 03:56 PM
Quoted: 391 Post(s)
Yep, you got it. Big car 400.
post #5 of 5 (permalink) Old 07-01-2017, 04:33 PM Thread Starter
Quoted: 9 Post(s)
Thank you so much for pointing me in the right direction. It's a new ride for me and I have a list of about 10 things I need to post.... :-) At least now I know what the block and head is. Now, for the rest of the million things.....
Thanks again -
Bredfan is offline
Need help decoding my engine block # mwinters 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 01-20-2015 08:15 AM
Decoding a 400 small block Shaffersphac 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 10-30-2014 12:08 AM
Actual differences between and RA block and non RA block DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-26-2010 12:07 PM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 10:55 AM
Help decoding gtocrazed 1964-1974 Tempest, Lemans & GTO General Discussion 6 06-04-2008 06:41 PM
