Determining Crank HP From RWHP - Pontiac GTO Forum
post #1 of 9 (permalink) Old 10-23-2011, 07:33 PM Thread Starter
I know this is going to open up a can of worms but here goes. What's the best to way to figure out your engine's crank HP from chassis dyno (rw HP) figures? I've heard take the rear wheel HP numbers and divide by .75, .80, .85 etc. depending on who I've talked to. Today I read and article from the GTOAA that stated the following:
RWHP divided by .85 = "Net" Crank HP (Net meaning alternator, fan. PS, full exhaust and other add ons are on engine).
Also, "Net" Crank HP divided by .80 = Gross Crank HP (as measured in the Sixties).
Thoughts and opinions are welcome.
67HardTop is offline
post #2 of 9 (permalink) Old 10-23-2011, 07:52 PM
HP11's Avatar
Quoted: 24 Post(s)
(I couldn't resist)
HP11 is offline
post #3 of 9 (permalink) Old 10-23-2011, 08:52 PM
68greengoat's Avatar
The calculations are right. Just depends on what number to use. I've heard you lose anywhere from 15 - 20% from the crank to the rear wheels. So that rules out .75. It sounds like GTOAA is saying you lose 15% which is why they use .85 as the figure... I would think GTOAA would have the more accurate info.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 9 (permalink) Old 10-23-2011, 09:37 PM
Quoted: 103 Post(s)
The only thing that matters is that you are not looking at the other guy's tail lights.
post #5 of 9 (permalink) Old 10-24-2011, 11:51 AM
It also depends on what transmission is in the car...and other things...
Eric Animal is offline
post #6 of 9 (permalink) Old 10-25-2011, 04:53 PM
Real answer? You can't. Not with anything close to 100% accuracy anyway, for two reasons:
1) Every dyno is different - run the same car (or engine) on two different dyno's and you're going to get two different results.
2) Parasitic loss in the transmission/drivetrain/rear axle --- varies too much from car to car, even with "the same components". "My" 3200 rpm stall converter, TH400, ujoints, drive shaft alignment, rear axle combination is going to absorb a different amount of torque than "your" 3200 rpm stall converter, TH400, ujoints, drive shaft alignment, rear axle combination is.
Real value of a chassis dyno session is for fine tuning your fuel system and ignition system so that they're "the best" for your particular car. Value of an engine dyno is for comparing different parts combinations and set ups on the same engine to find out which set up makes the best torque/power on that engine.
For real-world activities, we race cars - not dyno sheets
post #7 of 9 (permalink) Old 10-25-2011, 05:16 PM
Absolutely correct ^.
Chassis dyno's are tuning tools, they also help quantify gains (or losses ) from adding aftermarket accessories.
Generally speaking, figure 15% for stick shift cars and 20% for auto's.
post #8 of 9 (permalink) Old 10-27-2011, 07:35 AM Thread Starter
Thanks guys- appreciate the input. I guess I have no choice other than taking the car to the track and seeing what happens. Damn the bad luck...;-)
post #9 of 9 (permalink) Old 10-27-2011, 12:23 PM
Yeah, the things we endure for these cars - we're all saints, I tell ya...
69 GTO won't crank..... Eshack80 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-29-2010 08:49 PM
need help determining value on 71 Lemans. projectszero 1964-1974 Tempest, Lemans & GTO General Discussion 2 08-09-2010 11:52 AM
Best Source for Determining Buying/Selling Price LPTudor 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-03-2010 04:17 PM
Determining ratios asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-07-2010 03:06 PM
