Did anyone Install aftermarket A/C into a '68 GTO? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 11-07-2009, 12:41 PM Thread Starter
The climate here is mostly hot and I really need A/C in anycar that I would drive, I seached all over for a perfect fit A/C kit for my '68 GTO but it seems there isn't any, only the "generic" kits, anyone tried installing these kits in a '68-'72 GTO before? .. I'm not sure if its possible at all, or even if it would need alot of fabrications/modifications.
GasTiresOil is offline
post #2 of 16 (permalink) Old 11-08-2009, 07:38 AM
Contact Vintage Air they are SAID to be the best bet.
Eric Animal is offline
post #3 of 16 (permalink) Old 11-09-2009, 03:29 AM
Koppster's Avatar
I don't have a 68 but I do have Vintage Air in my car. I had an installer put it in, he used the chevelle kit with different vents, it fits very nicely.
Hot Rod Air offers systems as well and most I have chatted with say the quality is the same as Vintage: Hot Rod Air - Quality Air Conditioning Systems and Component Parts
Both are within 3 miles of my house
BTW, my installer adapted my controls to work with the Vintage unit. If my car had had vents, they would have plugged in to them as well.
Koppster is offline
post #4 of 16 (permalink) Old 11-09-2009, 07:58 AM
I plan on putting Vintage air in my resto-Goat. I have the lap vents, and the dash "eye ball vents" which I will install into the car (non-factory AC). Aftermarket AC fits under the dash, and is supposed to cool better, and have a better compressor......
post #5 of 16 (permalink) Old 11-09-2009, 08:21 AM
Koppster's Avatar
Eric...I can't speak for factory but I can tell you the Vintage Air unit is awesome...fringe benefits equal AC defroster/heater too
Koppster is offline
post #6 of 16 (permalink) Old 11-09-2009, 10:39 AM
Sounds good to me...if it cools in Texas, it should cool in NY..
post #7 of 16 (permalink) Old 11-10-2009, 02:15 PM
Quoted: 102 Post(s)
The newer systems are far less complex, have less components, are less bulky, lighter and cool better than the primitive original AC. They also use R134 refrigerant, which is readily available and doesn't cost a mint.
post #8 of 16 (permalink) Old 11-10-2009, 02:45 PM
Gator67's Avatar
The restoration shop I'm using specializes in classic Pontiacs, and is a dealer for Classic Auto Air, so I'm going with one of their systems.
Gator67 is offline
post #9 of 16 (permalink) Old 11-15-2009, 08:43 PM
crustysack's Avatar
I just started putting a vintage system in my 65 tonight, a couple of things came up- the unit is MUCH larger than a stock unit because the whole thing sits inside the car , I will have to cut my glove box down for it to fit, there is no way to attach the supplied defroster vents so I had to cut the originals and frankenstein em to the heat duct, even pushing the unit up as far as I can to the underside of the dash it still seems to low- and I had to move my fuse box that I had located above the tranny hump. I am sure these things are the norm with an aftermarket generic system
crustysack is offline
post #10 of 16 (permalink) Old 11-16-2009, 05:19 AM
Koppster's Avatar
Crusty
Can't speak to all of it but I did lose quite a bit of glove box on my installation, I was warned up front. My fuse box remains in the same position as before the installation (just left of the tanny hump).
For what it's worth, the guy that installed mine used the Chevelle kit...claimed it was a better fit.
Rick
Name:	GTO 23 Mar 09 009 compressed.jpg
ID:	5961   Click image for larger version
Name:	GTO 23 Mar 09 011 compressed.jpg
Koppster is offline
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Holden to end production of Monaro but Pontiac GTO to Continue 05GTO In the News 7 08-05-2005 08:17 PM
UK's Top Gear reviews the GTO. 1COOLPC 2004-2006 GTO General Discussion 4 08-10-2004 06:18 PM
