Difficulty in removing gauge assembly - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-17-2014, 08:12 PM Thread Starter
Reb
Reb's Avatar
We are in the process of (attempting to) disassemble the dashboard components on my '67. All was pretty straightforward until we came to the dash bezel. We lowered the steering column out of the way, removed all the fasteners securing the bezel, and eased it forward slightly.
But, now we are trying figure out how to remove the knobs and switches for the lights, wipers, and lighter. Basic guide on how to do so? Hate to force anything, and disassembly does not appear to be as straightforward as unthreading them.
Any other tips? Guidelines?
The factory service manual is not very descriptive in this area.
Reb is offline
post #2 of 9 (permalink) Old 01-17-2014, 09:55 PM
jmt455's Avatar
Headlight switch:
With the battery disconnected, pull the switch knob out. Reach behind the dash and press the release button on the headlight switch housing. It is a spring-loaded button, about 1/4" (6,5mm) diameter. Keep pulling the switch knob while the button is pushed; the knob and shaft will come out of the switch. Then, unscrew the switch attaching nut. It is a slotted, round nut that is visible after the switch shaft and knob have been removed.
Wiper switch:
Pull the knob straight off the switch.
Then remove the retaining nut that holds the switch to the dash panel.
Lighter:
Disconnect the power wire from the terminal at the rear of the lighter (round, spring terminal). Disconnect the lamp from the outer, rear housing(spring clip).
Hold the front of the lighter so it doesn't rotate and unscrew the outer housing from behind the dash.
HTH
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 9 (permalink) Old 01-18-2014, 11:25 AM Thread Starter
Reb
Reb's Avatar
Wow, those processes worked perfectly. Thank you so much! What about the key switch? We just unplugged it, but still need to remove the "key face place" in order to properly access the dash bezel for repaint.
I see there is a tiny hole in the front which I presume is a means to release the front plate. However, I have probed around in there with a torch tip cleaner, but am unable to feel anything to push on.
Any further advise would be much appreciated. Thank you!
Reb is offline
post #4 of 9 (permalink) Old 01-18-2014, 05:12 PM
Quoted: 23 Post(s)
Insert yrou key in the ignition and push a thick paperclip or small punch in the hole and push, your tumbler should release out of the housing along with the key.
Instg8ter is offline
post #5 of 9 (permalink) Old 01-19-2014, 04:25 PM Thread Starter
Reb
Reb's Avatar
Thank you. I was trying it without the key in the ignition. Note, I inserted the key, pushed the torch tip cleaner into the hole, and felt resistance. However, even depressed, the key faceplate and tumbler refuse to come out. Does it matter what position the key is in? Any further suggestions?
Reb is offline
post #6 of 9 (permalink) Old 01-19-2014, 05:02 PM
Quoted: 23 Post(s)
post #7 of 9 (permalink) Old 01-26-2014, 04:33 PM Thread Starter
Reb
Reb's Avatar
Have tried and tried, but no matter what, that key switch will not come out. Have tried rotating it (clockwise) with a push-pin pushed into the hole (with the key in place). Also tried prying it out with pin pushed in and key in place. No luck at all.
Reb is offline
post #8 of 9 (permalink) Old 02-01-2014, 07:47 PM
gtoguy389's Avatar
With your key in the ignition switch, and your paperclip or wire depressed in the small hole, you need to turn the key counterclockwise past the accessory position for the switch to pop out.
gtoguy389 is offline
post #9 of 9 (permalink) Old 02-03-2014, 07:28 PM Thread Starter
Reb
Reb's Avatar
It worked! Thank you all VERY much! : )
Reb is offline
Difficulty starting 69 Goat when cold droptop69goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 05-08-2013 03:32 PM
LS9 Crate into 2006 GTO, degree of difficulty? 9"Moser replacement for stock GTO IRS tem2006LS2plus Engine Discussions 23 07-14-2011 06:26 PM
Gauge trim panelwith round gauge in corners, cpr Interior Discussions 1 05-19-2011 04:14 PM
1972 Lemans Body mounts??? Difficulty? marcello7x 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-28-2009 09:52 AM
fuel pressure gauge & boost gauge sdgoat Service, Maintenance and Technical Discussion 4 05-12-2006 09:34 AM
