distributer 101 - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-10-2011, 06:01 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
distributer 101
Am I missing something here?
I thought there was some electrical connection between the bottom of the rotor and the points.
thanks as always
ID:	10572   Click image for larger version
Topkat is offline
post #2 of 3 (permalink) Old 03-10-2011, 06:09 PM
thanks as always
Nope, no connection at all - at least not anywhere inside the distributor. Know anything about electronics? The ignition coil is nothing but a big transformer. The points are really just a switch that operate to close and open the "primary" circuit in the coil. The constant making and breaking of the "primary" circuiit (turning it on and off) is what induces the high voltage spark energy in the "secondary" circuit inside the coil. The rotor under the distributor cap is what directs the energy created in the "secondary" circuit of the coil out to the correct cylinder.
post #3 of 3 (permalink) Old 03-10-2011, 07:24 PM Thread Starter
Topkat's Avatar
thank you Bear.......you da man.
Topkat is offline
distributer Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 03-18-2011 04:24 AM
distributer installation Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-10-2011 10:08 AM
Need help on distributer decision? nmiller5000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 09-03-2010 09:49 PM
Winter Tires 101 Discount Tire Wheels and tires 0 12-13-2008 01:25 PM
Grammer 101 1badgto The Lounge 12 12-02-2005 01:47 PM
