distributer installation - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-09-2011, 07:52 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
How do I install the oil pump driveshaft and distributer?
I know the motor needs to be at TDC on #1,with the timing marks lined up.. but how do I get the oil pump drive shaft onto the pump without it falling into the pan?.....lol
thanks as always and always
Topkat is offline
post #2 of 4 (permalink) Old 03-10-2011, 08:36 AM
Topkat,
I'm afraid the oil pump driveshaaft was supposed to be installed when the engine was "upside down" on the stand. Not all is "lost", though. This happens occasionally.
Grind the two little "titties" off the shaft. Get a "screw starter" that's large enough to hold the shaft tightly in the slot where the distributor shaft goes. Lower the shaft carefully into the hole, and rotate it slowly until the "lugs" line up and you FEEL the pump turn when you turn the driver. Release it. Anoither tool that works is a fairly powerful magnet with a "flat" surface. You can hold the shaft that way, too. Once it's engaged with the pump, slide the magnet to the side until it releases.
If the "dots" on the cam and crank gears are at 6 and 12 (o'clock) respectively, you are "up" on #6 "compression". That won't "cut it" when installing the distributor. The gears should have both dots at 12. THAT is "up" on #1. If the timing cover is already installed, remove the plug from #1. Put your finger in the hole. Rotate the crank until you feel compression escaping. This is called "blowing number 1". Continue to rotate until the timing mark is pointing at "0". You are now "up" on #1.
When actually installing the distributor, the oil pump drive can sometimes be an adventure to "engage". The easiest way is to have some light pressure on the distributor "down", and "bump" the starter until it drops all the way in. This takes two people... If the flange on the bottom is not flush with the block, it's NOT all the way down. Another way to "line up" the shaft is to turn it slightly with a large screwdriver and retry until it "goes". All the while, make sure when the rotation of the shaft stops, the rotor is pointing "at #1" on the cap.
Good luck and let us know how it comes out.
Jim
Mr. P-Body is offline
post #3 of 4 (permalink) Old 03-10-2011, 09:03 AM Thread Starter
Topkat's Avatar
why grind them off?
thanks
Topkat is offline
post #4 of 4 (permalink) Old 03-10-2011, 10:08 AM
Originally Posted by Topkat View Post
why grind them off?
thanks
Because otherwise you won't be able to insert the shaft through the boss inside the block that "holds" the top end of the shaft once it's installed.
If you don't grind them off, then the only way to install it is from the bottom with the oil pan and the oil pump removed.
Just to be clear here Top, what Jim is talking about grinding off IS NOT the slots on either end of the shaft!! It's the small bit of metal that sticks out from the side of the shaft, about an inch or so down from the top. You can see it in this photo, not quite to the right edge of the paper tag.
distributer Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 03-18-2011 04:24 AM
Need help on distributer decision? nmiller5000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 09-03-2010 09:49 PM
Clutch Installation Jim 1964-1974 Tempest, Lemans & GTO General Discussion 6 11-07-2008 01:16 PM
HID Installation raspantienator 2004-2006 GTO General Discussion 3 03-29-2008 07:05 PM
Hid Installation JGOAT Exterior Discussions 60 12-29-2007 01:43 PM
