Drive Shaft - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-12-2013, 04:41 PM Thread Starter
Drive Shaft
this should be easy to answer. my 69 drive shaft is thicker in the middle. It tapers down maybe a half inch one each end. One end the taper is about 4 inches from the yoke. On the other end, it tapers down about a foot from the yoke. When end goes toward the trans and which end toward the rear end?
funbooker is offline
post #2 of 5 (permalink) Old 10-12-2013, 07:00 PM
Well, strip my gears and call me shiftless....
I never noticed it was different on each end. It's not going to make a difference in how long it lasts or how strong it is. I'm guessing the different taper is there maybe for clearance reasons. My original '69 drive shaft is about 80 miles away right now, otherwise I'd go check it for you. (It still has the tranny yoke attached so I'd be able to tell). If'n it were me, I'd mock it up both ways and see if one way seems to make "more sense" than the other.
post #3 of 5 (permalink) Old 10-12-2013, 07:34 PM
Quoted: 105 Post(s)
Both of mine '65 GTO 4 speed and '67 GTO automatic have the short taper at the front and the longer taper at the diff. end. Not sure if '69 is the same, but I'd bet next month's pay on it.
post #4 of 5 (permalink) Old 10-19-2013, 05:49 PM Thread Starter
Thanks guys. It seems like the short taper should be at the front. I"m guessing it's something engineers did for some reason that doesn't have an explanation I"d understand. It doesn't seem to be clearance so it's gotta be something they figured out on a slide rule.
post #5 of 5 (permalink) Old 10-24-2013, 07:14 PM Thread Starter
I have another driveshaft question. The last time I put a universal in a big, American car, the retainer clips fit into grooves near the outside of the yoke. So the cups were inset the distance of the width of the clips plus a little metal for strength.
The manual shows the retainer clips going on the universal joint itself, inside the yoke and the cups. That might keep the joint from going past the inside edge of the yoke but what keeps the cup from popping out the end of the yoke?
Need drive shaft suggestions nassin79 Drive train, suspension, alignment and brakes. 6 10-12-2013 07:13 AM
drive shaft mikey9743 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2013 08:56 AM
Drive Shaft Stamp235 Drive train, suspension, alignment and brakes. 5 07-29-2007 01:43 PM
Drive Shaft Loops bluhaven Racing and Kill Forum 1 08-02-2006 12:52 PM
Drive shaft issue Afterglow 2004-2006 GTO General Discussion 2 04-01-2005 10:10 AM
