Drum Brake Pull - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-07-2017, 08:30 AM Thread Starter
Quoted: 9 Post(s)
Drum Brake Pull
Good Morning All,
Having difficulty pinning down the cause. the car is a 1969 Tempest. Over the winter, I replaced all the front suspension wear items (bushings, springs, steering components). I have replaced the front brakes, drums, wheel cylinders, and hoses. the alignment is good, and the tires are new.
When the car is first driven, it tracks straight when braking... As I drive the car for a period of time, when I brake hard, it will pull to the right.
I have readjusted the left front wheel to be tighter, but this same situation still occurs.
Any ideas where to go next?
thanks,
Armand
ajluzi1957 is online now
post #2 of 4 (permalink) Old 08-07-2017, 09:49 AM
the65gto's Avatar
Quoted: 12 Post(s)
Here is a guess that happened to me. Similar problem, pulling to the right, was the left brake hose. It was swelled up internally, limiting the fluid/pressure to left side, while the right was not restricted and braked normally. YMMV
the65gto is online now
post #3 of 4 (permalink) Old 09-29-2017, 05:59 PM
Yes I WOULD CHECK THE HOSES
Bruce Dodds is offline
post #4 of 4 (permalink) Old 10-01-2017, 11:14 AM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
1st post
BLK69JUDGE is online now
67 Rear Drum Brake 67PONGOAT 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 12-20-2015 02:20 PM
Drum Brake Help Falco21 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 07-20-2011 05:01 PM
Pick & Pull disc brake swap kjk990 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 04-24-2011 11:26 AM
drum brake assy. Topkat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 03-30-2011 12:54 AM
Ever pull parking brake on at 80 MPH? vnamvet 2004-2006 GTO General Discussion 19 10-11-2005 09:29 PM
