Drum to Disc Conversion Shouldn't have waited so long.... - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-05-2015, 12:30 PM Thread Starter
66 Tiger's Avatar
I just did a drum to disc conversion kit from summit racing on my 66 Leman's. What a difference it makes. Stops on a dime and and then some. I lived with the old drum brakes for 6 years they were okay however the front disc brakes make the Leman's feel like really light. I put in a kit that allowed me to keep my 14" Weld Wheels on the front, with a slight bit of modification the the caliper bracket. I included pics.
ID:	62162   Click image for larger version
ID:	62170   Click image for larger version
ID:	62178   Click image for larger version
66 Tiger is offline
post #2 of 2 (permalink) Old 08-05-2015, 04:27 PM
Quoted: 106 Post(s)
I did the same conversion on my GTO and kept all the original stuff to go with the car if I ever sell it down the road.
Once you get the pads seated adjust the proportioning valve until the rear brakes lock up under hard braking then back it off two clicks or so.
Play with it and when you get the car to squat under hard braking instead of the front diving you are there.
Goat Roper is offline
Classic GTO drum to disc conversion 05GTO 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-17-2018 08:33 AM
drum to disc brakes rbkagey 2004-2006 GTO General Discussion 0 11-24-2014 02:22 PM
69 Lemans drum to disc conversion Airdale 1790 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-20-2013 09:59 PM
Drum to disc conversion Hollismark 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 07-22-2012 09:05 PM
69 GTO Rear Drum to Disc Brake Conversion Kit jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 02-11-2012 04:55 PM
