dual gate shifter? - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-13-2011, 11:55 PM Thread Starter
skapegoat's Avatar
dual gate shifter?
Today when I was messing with the wires under my dash I noticed my shifter kept pushing to the side. At first I thought it was just loose but after a closer look I saw a there was a hinge at the bottom that let it swing to the side. Is this how a regular shifter is or do I have a dual gate shifter?
some may say i have too many projects
skapegoat is offline
post #2 of 11 (permalink) Old 03-14-2011, 07:21 AM
What year car? The '70?: the shifter shifts to the right and shifts like a dual gate.
post #3 of 11 (permalink) Old 03-14-2011, 07:44 AM Thread Starter
skapegoat's Avatar
It pushes to the right but not real far. It doesnt have the hurst shaft like the ones I looked up online, and it doesn't have the two slots on top either.
post #4 of 11 (permalink) Old 03-14-2011, 07:50 AM
Most '69-'72 GTOs and Firebird "400"/T/As had this shifter. It's a "ratchet" shifter. If you "pull" it into manual low, and hold it to the right while pushing forward, it will only go one "notch" at a time, effectively acting just like the Hurst "His & Hers", the dual-gate you're talking about.
Jim
Mr. P-Body is offline
post #5 of 11 (permalink) Old 03-14-2011, 09:03 AM Thread Starter
skapegoat's Avatar
So I just need to find a regular trim cover not one specific for this shifter?
post #6 of 11 (permalink) Old 03-14-2011, 11:18 AM
Correct. My 69 has one of these. Pull it down into low, then on the upshift, push it both forward, and "out" (away from you) at the same time in a diagonal motion and it will ratchet. If you still have the original "wood grain" insert in the console on the passenger side of the shifter, you'll see it has a small "1 2 3" embossed into it there.
post #7 of 11 (permalink) Old 03-14-2011, 07:43 PM
likethat's Avatar
I was redoing a 70 Firebird for a guy at work many years ago and it had that shifter. When I got in the car for the first time, I thought the shifter was broke.
67 GTO H.O. Convert 4spd
likethat is offline
post #8 of 11 (permalink) Old 03-14-2011, 10:33 PM Thread Starter
skapegoat's Avatar
I scoured the boxes of random goodies that came with the car and came up with 2 shifter bezels. The wood grain one did have the 123 numbers that were barely legible. The other must be another trans am part that was tossed into the boxes (I have found many). Now all I have to do is find a new wood grain cover. Thanks
post #9 of 11 (permalink) Old 03-14-2011, 11:51 PM
Quoted: 23 Post(s)
there is a thin plastic dust cover for the trim plate also that will have an oval cut out to allow the shifter to pivot w/o pushing the dust cover out of the channel, had a 69' firebird with the rally shifter, was Pontiacs answer to the hurst when they drummed them out, a lot cheaper than the his/hers and basically does the same thing. I fabbed a B&M quicksilver ratchet into my factory console and plate handle looks like the hurst and its a lot heavier duty unit than the stock ones if you like to slam gears. Used to go through a cable a year if i remember right. Shiftworks makes some nice cables that are a lot more flexible than the stock ones and will not kink.
Instg8ter is online now
post #10 of 11 (permalink) Old 03-15-2011, 06:15 AM
Mine works great. Shift into L. Push shifter to the right, give her hell ratchet into S then into D.
Sounds and feels like manual.
GTO Hurst Dual Gate Shifter Question SlowAces 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-12-2013 03:38 PM
Where to find Hurst dual gate? clarkaim 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 15 11-29-2010 10:27 PM
Hurst Dual-Gate GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 02-23-2009 07:55 AM
Hurst Dual Gate for 70 Ragtop70 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-18-2006 11:08 AM
