Dual Snorkel Air Cleaner Identification - Pontiac GTO Forum
post #1 of 13 (permalink) Old 11-05-2009, 09:42 AM Thread Starter
I am trying to figure out exactly what year and model vehicle this air cleaner came off of? Any help would be greatly appreciated. I think it is late 60's early 70' GTO???
chevelleman is offline
post #2 of 13 (permalink) Old 11-05-2009, 10:31 AM
646904GTO's Avatar
Looks like the one on my 1969 GTO. Very rare to find one these days since most were replaced with a full open aftermarket ones. Hang on to that gem!
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #3 of 13 (permalink) Old 11-06-2009, 05:01 PM
68_Goat's Avatar
Its likely 69-72 GTO....I have a green stenciled date on the inside of mine....from what I understand, there are some subtle physical differences, but I'm not sure what they are. 68 only had one snorkel.
68_Goat is offline
post #4 of 13 (permalink) Old 11-06-2009, 07:08 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Since he's a Chevelleman, it's most likely on ebay by now...
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #5 of 13 (permalink) Old 07-13-2018, 02:07 PM
what is the correct air cleaner for 68 GTO 400-4?? "HO"
donb is offline
post #6 of 13 (permalink) Old 07-13-2018, 03:23 PM
BLK69JUDGE's Avatar
Quoted: 42 Post(s)
and
Name:	9-25-09 craigslist 055.jpg
ID:	114137   Click image for larger version
Name:	9-25-09 craigslist 049.jpg
BLK69JUDGE is online now
post #7 of 13 (permalink) Old 07-13-2018, 09:00 PM
Quoted: 321 Post(s)
Dual snorkel, chrome lid.
post #8 of 13 (permalink) Old 07-14-2018, 04:11 PM
thanks Pontiac Jim
That's is what I thought - and then was recently told the dual snorkel chrome lid did not appear until the 69 model year.
I found a new / old on-line last week for $290 so I bought it to get away from the after market open chrome lid someone before me replaced it with. trying to get as original as I can.
see you are in Gastonia - I was in Statesville before moving to Austin, Tx about 22 years ago.
thanks for your help
DonB
donb is offline
post #9 of 13 (permalink) Old 07-14-2018, 04:39 PM
Quoted: 73 Post(s)
According to my catalogs....single snorkel for 68 and dual for 69. Never seen an original 68 with dual snorkel air cleaner...
Shake-N-Bake is offline
post #10 of 13 (permalink) Old 07-14-2018, 05:54 PM
Quoted: 321 Post(s)
YOU are correct. My bad. I recall a forum discussion on this and simply could not find it to reflect back on. However, I did finally find it: https://www.gtoforum.com/f178/68-400-ho-details-125401/
I had quickly referenced the Pontiac GTO Restoration Guide and read the text which did not clarify. Did not find a photo which I thought it had - but I just found it going through the book again. Single snorkel, chrome lid, painted 60% gloss.
The HO used the same air cleaner as any GTO, single snorkel with chrome lid. 1969 and up had the dual snorkel and Pinion head provided a very detailed description of the different types. The only fly in the ointment was the supposedly original 1968 GTO HO 400 written of in Hemmings which had a dual snorkel. It was never determined if the owner installed this himself along the way OR it may have been a very late 1968 build that got the 1969 dual snorkel air cleaner - 'cause Pontiac did things like this.
So check out the thread and this should clarify. Personally, dual snorkel would be on my engine if I were to run something other than an open element air cleaner which I prefer and run. Something about the visual balance of two snouts versus just the one.
A very interesting test was done by Engine Masters on air cleaner flow. One test included a dual snorkel air cleaner on a 750 HP engine. The dual snorkel showed a loss of 53 HP. When flipping the lid over, it lost only 11.9 HP. The best was an open velocity stack which increased HP by 5.7 HP and the fly in the ointment that came in as second best was a fitted salad bowl which increased HP by 3HP.
Keep in mind this 750 HP engine was no doubt a big breather and it spun some higher RPM's. I don't think you would see the same kind of losses on a lower RPM/HP type engine.
Name:	TOP 20 Air Filter Combinations on 750 HP engine.JPG
ID:	114155   Click image for larger version
Name:	TOP 10 Air Cleaner Combinations on 750 HP engine.JPG
GTO history 05GTO 2004-2006 GTO General Discussion 9 08-16-2009 05:26 PM
correct air cleaner for 71 400? camarocasanova 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-06-2008 10:43 PM
Simple mods worth it ??? Ursus Service, Maintenance and Technical Discussion 54 07-09-2008 01:04 PM
Hot data on cold air induction. Important. wakarr Service, Maintenance and Technical Discussion 24 12-03-2004 09:45 AM
