dumb question about power,69 gto - Pontiac GTO Forum
post #1 of 8 (permalink) Old 05-12-2009, 11:01 AM Thread Starter
skuzzzusmcdevildog's Avatar
ok so the 73 trans am engine that i have has 230 HP or more if Pontiac changed the compression by heads could i get 350 horse by changing the heads to 87cc Eldelbrock head , up the 650 carb to a 750 keep the intake maybe change the cam i dont know i dont want a crazy cam gas already sucks lol and if not how much hp can i expect to gain i know this is almost impossible to answer but i just figured i would ask just the same
skuzzzusmcdevildog is offline
post #2 of 8 (permalink) Old 05-12-2009, 12:08 PM
Quoted: 105 Post(s)
With the heads, carb, and a decent cam (068 or comparable) you'd be in the 320-350 HP range. It would be a "bread and butter" totally drivable engine.
post #3 of 8 (permalink) Old 05-12-2009, 07:21 PM Thread Starter
thank you im having trouble locating that cam for the gto
post #4 of 8 (permalink) Old 05-12-2009, 07:33 PM Thread Starter
Cams??
magnum cam,,,lift481 loap sep 110 duration 280 dual #ccacl513144?? orcam#516 lift 114lobe center 308 320 duration
post #5 of 8 (permalink) Old 05-13-2009, 05:35 PM
67 Basket Case Restorer
Too Many Projects's Avatar
068 are the last three numbers of the factory part number for a particular cam. Any cam that has similar specs to a factory tripower or ram air cam will be good. One thing to remember about the hp rating on the 73 you have is that it's net, or flywheel as installed, hp for insurance purposes. The gross hp is still probably 275 or so.
My 73 Motors Manual shows the 73 cam specs as still very close to the earlier years for lift with a little less duration so the cam is close. Like Geeteeohguy said, the heads are probably going to give you a noticeable increase and a bigger carb will help too.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #6 of 8 (permalink) Old 05-13-2009, 06:37 PM
The BHP ratings prior to 71 were calculated on dynos using headers and without the loses from water pumps, alternators, power steering pumps and A/C compressors, after 71 the sae HP ratings were calculated as Mitch mentioned "as installed" and were lower for insurance requirements.
When I had my 66 389 motor rebuilt they dynoed it the old fashion way and I was able to get the BHP numbers you are looking for or what the factory stated prior to 71.
05GTO is offline
post #7 of 8 (permalink) Old 05-14-2009, 08:43 AM
xcmac26's Avatar
Quoted: 5 Post(s)
holystreamofconciousnessbatman!!!
xcmac26 is offline
post #8 of 8 (permalink) Old 06-04-2009, 06:32 PM Thread Starter
thanks just got back from field op you devil dogs know how those are
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Holden to end production of Monaro but Pontiac GTO to Continue 05GTO In the News 7 08-05-2005 08:17 PM
GTO owners,i Got a buying/monthly Question logigamer Southeast 1 03-22-2005 03:16 PM
UK's Top Gear reviews the GTO. 1COOLPC 2004-2006 GTO General Discussion 4 08-10-2004 06:18 PM
