Dyno Results: - Pontiac GTO Forum
post #1 of 19 (permalink) Old 08-21-2014, 10:12 PM Thread Starter
Dyno Results:
dyno results
I have purchased a 1968 YH block 428 375 hp engine, it has 3 angle valve job with 6x heads being hogged out to 2.18 and 1.89 I have headers and 1966 tripower stock and cam reads 474 lift with 304/296 duration compression has been lowered to 10.1 My question is what do you think estimated horsepower/torque would be for this engine. Someday I will get to a dyno for real results. Thanks!
ottfive is online now Forward Message
ottfive is offline
post #2 of 19 (permalink) Old 08-22-2014, 05:53 AM
RunninLeMans's Avatar
Do you have the 0.050" duration for the cam? I'll run this combo on the dyno simulator.
RunninLeMans is offline
post #3 of 19 (permalink) Old 08-22-2014, 09:33 AM
Quoted: 103 Post(s)
Don't know about power numbers, but you will need race gas for that engine at 10:1 with iron heads.
post #4 of 19 (permalink) Old 08-22-2014, 09:54 PM Thread Starter
Exhaust is 2.5 3 angle valve job, no mention of head port rocker ratio 1.50,
Cam specs;ERSON degrees of duration 228 235 intake open 38 overlap 81 exhaust closes 43 intake closes 78 exh opens 83 valve lift int .472 296/306 exh valve lift .472 exh gr lift 315 degreeing cam int open 4 tdc overlap 11.5 exh close 44 exh open 47.5 gr lift intake .315 Thanks for any info you can give me!
ottfive is offline
post #5 of 19 (permalink) Old 08-22-2014, 09:57 PM Thread Starter
I've been running 93 octane with booster with no problems yet, it does have harden valve guides for todays gas. Any one else running this comp ratio had any problems?
ottfive is offline
post #6 of 19 (permalink) Old 08-23-2014, 09:27 AM
You could be getting lucky. Still, I'd heartily recommend that you frequently inspect your spark plug tips using a magnifying glass, looking for "shiny specks" until you're sure you're not having problems. There is such a thing as detonation that isn't pronounced enough for you to hear as knocks, but can still chew up your piston tops (where the shiny specks come from) over time.
I think you may have meant hardened valve seats, not guides, yes?
It's pretty unusual for someone to be able to run at 10:1 with iron heads and pump gas without having problems.
post #7 of 19 (permalink) Old 08-23-2014, 10:40 AM Thread Starter
Thanks Bear,
I will check and yes I meant hardened valve seats. Would a 9:5 0r 9:1 comp ratio be recommend for today's gas? Or what octane racing gas should I use with current 10:1 ratio? Thanks for your help!
ottfive is offline
post #8 of 19 (permalink) Old 08-23-2014, 01:10 PM Thread Starter
ottfive is offline
post #9 of 19 (permalink) Old 08-24-2014, 08:14 PM
Sorry for the delay, bud, gone for the weekend. I had to rough in a couple things, no tri-power in my data base, but with an 800 cfm Holley double-pumper and the rest of what you gave us I get 432 hp @ 5250 rpm and 479 ft-lbs @ 3500 rpm. I've run a few engine builds with actual dyno results on this software and it's usually a little optimistic, but you still got a healthy motor there. Maybe one of the real engine builders has better tools...
Scott
post #10 of 19 (permalink) Old 08-24-2014, 08:20 PM
Bear, you think that late-closing intake valve is helping him out with lower dynamic compression in spite of the 10:1 static number? I get 7.1:1 with the Wallace Racing calculator, ain't that in the okay range for 93 octane?
Dyno Results Dr.Goat 2004-2006 GTO General Discussion 3 06-03-2014 07:02 AM
dyno results JUSTIN4102 2004-2006 GTO General Discussion 14 04-25-2011 10:23 PM
Dyno Results Audi Killer 2004-2006 GTO General Discussion 9 04-10-2011 12:37 PM
04 A4 Dyno Results TORNATIC!! Engine Discussions 17 11-15-2007 04:31 PM
Dyno results! 6QTS11OZ Engine Discussions 21 10-06-2006 03:32 PM
