Educate me on '68 gauge clusters... - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-03-2011, 03:16 PM Thread Starter
SixTeight's Avatar
So I had been collecting dash pieces one by one and have accumulated a gauge cluster and rally clock. The gauge cluster is stamped "APR 3 68" and has "idiot lights" for oil and water.
While I was searching for a dash to house these in, I ended up picking up a dash with a whole set of gauges already installed, which was apparently from another '68 but I can't find the date stamp on it. This gauge cluster is identical with the exception of having actual water and oil gauges.
Both sets of gauges look pretty clean. My car was built in February '68. Obviously the gauges stamped for April were made afterward but I am wondering which gauges are "factory correct"... Should a Feb. '68 car have gauges or lights for oil and water? Thanks for your help!
SixTeight is offline
post #2 of 7 (permalink) Old 06-03-2011, 03:45 PM
68GTO4004Spd's Avatar
Mine has guages for water, fuel and oil press. and an idiot light for generator. I'm at work so I can't get the date codes right now, maybe later this weekend I could get that for you.
68GTO4004Spd is offline
post #3 of 7 (permalink) Old 06-03-2011, 04:59 PM
68greengoat's Avatar
Depends on what's on your PHS. Rally gauges, like the one 68GTO400 has, were an option. The idiot lights like the one that's stamped APR 3 68 were standard.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 7 (permalink) Old 06-03-2011, 06:00 PM
hmmm I need to do that PHS thing, I had no idea those were optional gages, I knew the tack instead of the clock was an option, but I didn't know gages over idiot lights. Looks like my idiot light is on.
post #5 of 7 (permalink) Old 06-03-2011, 06:33 PM Thread Starter
SixTeight's Avatar
I have been procrastinating on ordering those as well... I think I like the "rally gauges" better anyway tho... so I'm betting that if my PHS docs say it came with the standard gauges, I'll still be putting in the rally gauges
With the tachometer, I was under the impression that the hood tach was the "option" and if you selected that you got the clock and if not, the in dash tach came standard?
post #6 of 7 (permalink) Old 06-03-2011, 06:44 PM
does not matter what dates, no one is going to tell once installed unless you show them by the PHS that it did not come with gauges.
pontiac is offline
post #7 of 7 (permalink) Old 06-03-2011, 08:52 PM
Yes, the hood tach was an option and may be tied to the clock too. You could have a seperate hood tach option and clock option. So you could have,or not, a hood tach with a clock. It doesn't appear it was standard to get a clock if you had a hood tach, but was an option. There is a Rally Gauge/ Instrument Panel Tach option and a Rally Gauge/Clock option. Standard was no clock and no tach. I have a delete plate for the clock/panel tach....
SOLD.....
462ci, 4spd
Aussie guage clusters... IRONSIGHT Interior Discussions 7 02-27-2011 02:53 AM
65 Guage clusters olde-goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 12-21-2010 12:19 PM
Educate me! sleepindirty Drive train, suspension, alignment and brakes. 3 05-08-2010 05:12 AM
Educate me on media blasting [email protected] 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2009 09:53 AM
