elect. choke - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-07-2011, 06:58 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
elect. choke
can I run my elect choke off the + of the coil?
thanks as always
Topkat is offline
post #2 of 8 (permalink) Old 10-07-2011, 08:00 AM
I wouldn't...but it will work. Mr. Coil likes to work alone!
Eric Animal is offline
post #3 of 8 (permalink) Old 10-07-2011, 09:23 AM Thread Starter
Topkat's Avatar
where else in the eng. compartment could I put it?
the alternator?
thanks as always
Topkat is offline
post #4 of 8 (permalink) Old 10-07-2011, 09:35 AM
Anything thats hot when the ignition is ON...
post #5 of 8 (permalink) Old 10-07-2011, 10:33 AM Thread Starter
Topkat's Avatar
Thanks Uncle E.
heading to vegas next weekend..............
Topkat is offline
post #6 of 8 (permalink) Old 10-07-2011, 08:29 PM
thanks as always
no. the coil wire is a resistance wire calibrated for coil voltage alone.
freethinker is offline
post #7 of 8 (permalink) Old 10-07-2011, 10:02 PM
billcocarb's Avatar
I normally run the electric choke on separate 14 gauge wire through firewall and to fuse box to ignition hot terminal. I also always run it through an in line fuse.
billcocarb is offline
post #8 of 8 (permalink) Old 10-07-2011, 11:09 PM
likethat's Avatar
On the 67 Camaro I ran it from the horn relay.
67 GTO H.O. Convert 4spd
likethat is offline
carb choke linkage Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-02-2011 11:20 PM
67 gto 2bbl carb choke problem bnichols04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-08-2007 10:04 AM
67 lemans 2bbl electirc choke? bnichols04 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 09-06-2007 09:03 PM
Choke problem? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 06-07-2007 09:21 PM
heat choke quest my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 7 04-13-2006 07:34 AM
