Electrical gremlin - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-04-2017, 01:26 PM Thread Starter
Electrical gremlin
On a 67 GTO coupe the dome light goes on with the brake light, has anyone ever run into this or can you suggest a starting place to look for this problem.
DanJuhasz is offline
post #2 of 3 (permalink) Old 09-04-2017, 06:36 PM
66jr's Avatar
I find most electrical issues are grounding problems. Make sure everything on that circuit has a good strong ground.
66jr is offline
post #3 of 3 (permalink) Old 09-04-2017, 07:31 PM
pjw1967's Avatar
Check the clips that hold the bulb in the housing of the dome light. The dome light is on the same circuit as the brake lights. Many years ago I inserted the torpedo bulb and managed to push one of the metal clips through the housing so that it grounded on the underside of the roof. I would step on the brake and the fuse would blow. Hope this helps.
pjw1967 is offline
Need electrical help for an 06 clarkr11 Interior Discussions 7 02-19-2014 09:06 PM
64 gto electrical Jim Rich 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-02-2012 08:33 PM
Another electrical ????? 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 08-22-2011 04:56 PM
2004 GTO headlight, turn signal, Tail light etc... electrical gremlin? Nerty77 Service, Maintenance and Technical Discussion 0 05-05-2010 01:21 PM
Electrical Gremlin Repaired lccrosby Service, Maintenance and Technical Discussion 1 06-03-2005 02:12 PM
