Electrical probs 70 GTO - Pontiac GTO Forum
post #1 of 7 (permalink) Old 10-13-2011, 04:19 PM Thread Starter
I am having electrical trouble with recently purchased and restored 1970 GTO
I dont know much about electrical.
No power to: Gas gauge, instrument lights, blower motor
I replaced fuse to blower with no results.
Any help appreciated?
GTOmaine is offline
post #2 of 7 (permalink) Old 10-13-2011, 05:40 PM
Did you check the dash fuses in the fuse box? I think there is one labeled instrument panel, or something close.
Do you have and/or know how to use a dvm? (digital volt meter)
Russ
russosborne is offline
post #3 of 7 (permalink) Old 10-14-2011, 12:10 PM
electrical trouble 1970 GTO
none of these circuits are in common with one another. Doubt if you know there is no power to gas gauge. Gauge not working is not a power issue usually. Dash? lights or do you mean instrument idiot? lights? Dash are usually ground issues. Blower motor varies if AC or non AC. Look in factory service manual for first hand info. Best source of detail. Then from there can better answer any questions. Need more detail on each item.
pontiac is offline
post #4 of 7 (permalink) Old 11-20-2011, 12:06 AM Thread Starter
I did replace all fuses.
Gas gauge read FULL all the time,
Instrument lights all 3 pods are out.
The car does have AC
GTOmaine is offline
post #5 of 7 (permalink) Old 11-20-2011, 12:09 AM Thread Starter
Not idiot, illumination for guages out
GTOmaine is offline
post #6 of 7 (permalink) Old 11-20-2011, 01:37 PM
The gas gauge problem may be a missing ground wire from the sending unit on the tank to the chassis. Try grounding the wire at the tank that goes to the gauge and see if it changes the fuel level indicator.
05GTO is offline
post #7 of 7 (permalink) Old 11-21-2011, 03:26 PM
With regard to the dash lights... did you turn the headlight switch counter clockwise? Just checking.
Matthew is offline
Another electrical ????? 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 08-22-2011 04:56 PM
Electrical Issue ty367050 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-21-2010 03:27 PM
Spent the night at the track and having probs taylorb765 Drive train, suspension, alignment and brakes. 9 10-01-2010 10:52 PM
Run the motor with no electrical? JoeKramer 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 11-25-2009 08:23 AM
Clutch Probs? Aftermarket? BlownGTO Drive train, suspension, alignment and brakes. 8 02-17-2006 08:00 AM
