Engine too hot - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-13-2016, 05:14 PM Thread Starter
DirtyD's Avatar
Engine too hot
Looking for some advice. I installed a new Griffin radiator in my 66 GTO. I am still using the original fan. Running around town the temp is about 180. But if I get stuck in traffic the temp is jumping up to around 230.
Any ideas?
Thanks as always
DirtyD is offline
post #2 of 6 (permalink) Old 03-13-2016, 08:25 PM
Lemans guy's Avatar
Quoted: 70 Post(s)
That is a classic symptom of a bad fan clutch.....at idle runs hot...that is when the clutch should run the fan, and not slip, either by Centrifigal fluid or temperature.....
Observe the fan at idle is it spinning strong? Or slipping? It should be spinning strong........watch your fingers around fans.....
Watch the fan when you shut the car off...have a helper turn it off.....does fan stop pretty quick?.....or spin and spin?
Free spinning at shutoff means it is not catching at idle ..it is supposed to slip at speed and catch at idle
Lemans guy is offline
post #3 of 6 (permalink) Old 03-14-2016, 09:36 AM
Does it have the fan shroud on??
post #4 of 6 (permalink) Old 03-14-2016, 09:54 AM
chuckha62's Avatar
Quoted: 18 Post(s)
^^^^This! If you've changed radiators and not adapted or otherwise installed a corresponding shroud, your fan isn't going to pull air through the radiator properly in traffic.
chuckha62 is offline
post #5 of 6 (permalink) Old 03-16-2016, 09:17 PM
Why did you replace the existing one? Was it doing the same thing before you changed the radiator. Is it stock 389?
tonyli is offline
post #6 of 6 (permalink) Old 03-20-2016, 02:38 PM
Quoted: 118 Post(s)
Hot in traffic but normal going down the road is a classic sign of a fan problem: you are not pulling enough air through the radiator core to cool the engine. Fan shrouds are a big help, as well as the correct fan and fan clutch assembly. The fan blades should be half in, half out of the shroud when properly set up.
Hot hot hot gjones 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 23 03-26-2013 07:44 PM
engine turns over slow when hot khinton 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 03-23-2011 07:58 PM
how hot its to hot? tyler t 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 02-05-2011 12:35 PM
66 GTO engine runs too hot jerry davis 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 11-02-2009 11:08 AM
Hot Engine? Phil's06 Engine Discussions 7 05-05-2007 01:43 PM
