Engine won't turn over - Pontiac GTO Forum
 4Likes
  • 1 Post By Pinion head
  • 1 Post By PontiacJim
  • 1 Post By alanmay0
post #1 of 8 (permalink) Old 11-21-2017, 07:00 PM Thread Starter
alanmay0's Avatar
Hello again, Well I put a little mystery oil in my cylinders of my 1967 GTO today and then went to turn it over by hand. It only turn about 1/4 turn and then it hits something solid in the engine and won't turn any farther. I can then turn it back the other way again for about 1/4 turn and then it hits something solid.
Now it was turning over fine about a month ago. Then about the same time I used a converted distributor and a drill and spun the oil pump to get oil throughout the engine. The valve covers were off and I could see the oil coming out of the push rods so I quit and put the valve covers back on.
Yesterday I went to prime the engine with oil again and used the same technique but no oil was observed so I quit.
Now today I went to turn the engine over by hand and as I stated above it hits something solid.
I a wondering if maybe I damaged the oil pump or something came loose in the oil pump and is now preventing the engine from turning over.
Any and all suggestions will be welcome. I dread having to pull the oil pan off to inspect it if there is an easier way.
Thank all of you for you help on many subjects.
alan
Alan
alanmay0 is offline
post #2 of 8 (permalink) Old 11-22-2017, 12:06 AM
Quoted: 106 Post(s)
Pull the valve covers and check the springs and make sure you don't have a dropped/stuck valve.
Are you turning the oil pump counter clockwise?
Are the plugs out?
If not you could be hydraulicing the piston(s) with the Mystery oil.
Goat Roper is offline
post #3 of 8 (permalink) Old 11-22-2017, 09:50 AM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
pull the plugs. if it's hydraulic lock that would fix it.
64GTOConvertible is offline
post #4 of 8 (permalink) Old 11-22-2017, 11:13 AM
My bet is oil pump driveshaft has dropped down, not engaging oil pump, & is now jammed up against crank throw. Going to have to pull the distributor, & get in a position to see the problem. At least you have a '64-67 where typically, there is enough room to contort ones body & look down the distrib hole.
Bredfan likes this.
post #5 of 8 (permalink) Old 11-22-2017, 04:37 PM
the65gto's Avatar
Quoted: 12 Post(s)
The OP driveshaft dropping down, is that a common thing?? Happened to me once and scared the CR.. out of me. Thought I would have to pull the engine to get it out but found a super magnet and put it on a long stick and was able to get it out. I think the shaft kind of sticks in the bottom of the Dist and then drops back in missing the right spot?? I would clean both and make sure it is free for the next removal.
the65gto is online now
post #6 of 8 (permalink) Old 11-22-2017, 06:41 PM
Quoted: 391 Post(s)
Read this post: https://www.gtoforum.com/f178/stuck-oil-pump-123042/
Bredfan likes this.
post #7 of 8 (permalink) Old 11-22-2017, 06:44 PM
Quoted: 391 Post(s)
X2, oil pump shaft probably got lifted up and out when you took off the oil priming tool and it may have dropped down into the engine. Read this post: https://www.gtoforum.com/f178/not-sur...-doing-112257/
Bredfan likes this.
post #8 of 8 (permalink) Old 11-23-2017, 04:57 PM Thread Starter
alanmay0's Avatar
Problem solved, it was the oil pump shaft. I pulled it out of the engine using a pair of needle nose pliers today. Will order a new one tomorrow. Thank you all so very much for your advise. Most always get good answers on the forum.
Bredfan likes this.
Alan
alanmay0 is offline
BRAKE ! Message won't turn off. nl18145 2004-2006 GTO General Discussion 1 10-14-2014 08:51 AM
Fog lights won't turn on Gto-noob Exterior Discussions 8 01-15-2013 07:18 PM
key won't turn! banshee Service, Maintenance and Technical Discussion 21 07-19-2010 09:02 AM
Key Won't Turn GM Kid 2004-2006 GTO General Discussion 31 10-01-2008 09:59 AM
T/C won't turn back on!!!!!! QSGTO Service, Maintenance and Technical Discussion 10 01-31-2006 03:01 PM
