Ever have one of those days? - Pontiac GTO Forum
post #1 of 14 (permalink) Old 12-14-2012, 07:55 PM Thread Starter
leeklm's Avatar
When one small project leads to a bigger project, which leads to a bigger project... etc.
I promissed the wife that I was not doing a frame-off for many years, but was hard to convince her of that after she saw this. It started as simply pulling the old 400 for a new 455 build. What a great time to detail the engine compartment a little! Well, one bolt leads to another then to 200, and you get this...
Oh well, made me smile. But I had to promise her I would not be posting pictures to the "restoration thread" here on the forum anytime in the near future!
I do need to do a little research for good paint options, etc. to obtain a decent looking finished project.
If you are still reading what recommendations do you have for cleaning/degreasing the frame without making too big of a project out of it?
leeklm is offline
post #2 of 14 (permalink) Old 12-15-2012, 09:17 AM
Actually, last year it happened to me.... a simple engine pull to clean it up check it out and repaint went from 200 to well over 2,000 $ job.... one thing led to another, once the engine was out I could not see putting back old parts.. 99% was replaced under hood. 40 years of people doing it all wrong.... well, it wasn't going back like that. Every day I was ordering parts and running to NAPA it seemed. When it was all done? Glad I did it.. now its done.
The plan was to do this this winter that next winter and then eventually all would be completed in due time.. Well, this led to that and that to that.. I called it the accelerated Git -R-Dun program. This is actually the first winter I had it I am not working on it accept detailing and some minor things. Now once I can convince her I need that '67 rag top I can start over again.... she will eventually warm to this proposition..... maybe
post #3 of 14 (permalink) Old 12-15-2012, 09:53 AM
Go rent a power washer
post #4 of 14 (permalink) Old 12-15-2012, 10:17 AM
Actually that is what I did once the engine was out and the car in the drive. I blasted the grime and painted mud and dirt away most of it anyway.. I bagged off areas I didn't want wet and carefully power washed everything. I got it to bare metal in most areas, it eliminated a lot of sanding. Once dry I applied degreaser brake cleaner to prep the surfaces for primer and paint. Turned out rather well for a novice. The Eastwood paints applied still look fresh and new.
Pics before is after power washing and before sanding and grinding, the cooling lines and hoses motor mounts etc were old and replaced after new paint applied. The AC hose clamp was also removed and replaced with the proper bracket since the car never had AC.
Eastwood's Rust Encapsulator as the primer was used then their Extreme Chassis Black on the chassis and chassis components, then their Underhood black on everything else.
ID:	16265 Click image for larger version
ID:	16266 Click image for larger version
ID:	16267Click image for larger version
ID:	16268Click image for larger version
post #5 of 14 (permalink) Old 12-16-2012, 09:40 AM
MaL
MaL's Avatar
Send a message via AIM to MaL
I was going to clean up the front clip only, but when I saw the front body bushings, I knew I was going to now separate the body from the frame... 5 years later... still plugging away and not driving it...ugh!
MaL is offline
post #6 of 14 (permalink) Old 12-16-2012, 10:55 AM
Quoted: 102 Post(s)
5 YEARS?? Yikes. When I pulled my engine in March of '11 for a reseal job, I almost fell into "just going ahead and pulling the body to do the rest of the undercarriage". Glad I didn't. I just did the engine compartment and steam cleaned the underside and left it at that. I've put almost 4,000 fun-filled miles on the car since then, and am driving it every week, just as I've always done. I can't imagine having a GTO but not being able to drive it for years on end. But, a LOT of people I know are in that exact same predicament. It's all about your priority, and life can get in the way sometimes. Good intentions soon get sidetracked, loose focus, and then run out of steam. The key is, to delegate a small amount of time to work on the car every day or week no matter what....and it'll get finished. Like keeping in shape with exercise. It has to be regular. That's the only way that I know of, short of having unlimited spare time and no commitments, which is pretty rare!!! Good luck bolting it all back together!
post #7 of 14 (permalink) Old 12-16-2012, 06:35 PM
That was me for more than 20 years.... Had it not been for my sweet bride, it'd probably still be sitting in pieces.
post #8 of 14 (permalink) Old 12-16-2012, 09:01 PM
I started a project 3yrs. ago......it's almost finished now.... Eric
Eric Animal is offline
post #9 of 14 (permalink) Old 12-17-2012, 09:15 AM
Quoted: 102 Post(s)
Eric, My friend Bill's GTO that was finished about 2 years ago took us 3 years to do. I think for most mortals, with time/money constraints, 3-5 years is pretty typical. I got him "motivated" to get moving on it....like Mr. GFR, Bill's car had been sitting for 20 years...When we were done, he had his 21 year old son drive it, and the boy had never seen it run prior to that his whole life!!! Priorites being what they are, timeframes are different for everyone. The goal is not to get overwhelmed and burn out. Speaking of overwhelmed, good luck on the household reconstruction and wishing you a great Holiday season and short work of all of the 'stuff' you're dealing with.
post #10 of 14 (permalink) Old 12-17-2012, 10:54 AM
Amen to that! Here's a photo of my older son, taken when I started on the restoration:
When he saw the car move under it's own power for the first time in his life, he was 27 years old. He was also the first person to drive it, other than me. It was cool that he got to help me build the engine though...
Buying my first GTO in a few days par4n1 1964-1974 Tempest, Lemans & GTO General Discussion 27 02-02-2010 12:39 PM
I'll be hibernating for the next few days... Too Many Projects 1964-1974 Tempest, Lemans & GTO General Discussion 19 01-14-2009 05:34 PM
Some Days are better than others NJG8GT The Lounge 9 01-04-2008 07:38 AM
I am 3 days old bigmac Member Introductions 2 07-10-2006 02:08 AM
A few last days . . . PWR_SHIFT 2004-2006 GTO General Discussion 20 12-05-2005 08:02 PM
