ex manifolds - Pontiac GTO Forum
post #1 of 21 (permalink) Old 02-14-2011, 06:38 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
ex manifolds
I'd like to thank everyone in this wonderful forum for the INVALUABLE assistance and patients provided.
No one ever called me a dumb ass lol
BUT..............how in the heck...............
do ya get the exhaust manifolds on?
the passenger side appeared to be the easiest........NOT
do i have to lift the motor?
thanks as always
Topkat is offline
post #2 of 21 (permalink) Old 02-14-2011, 06:46 PM
66tempestGT's Avatar
from bottom up maybe.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 21 (permalink) Old 02-14-2011, 07:05 PM Thread Starter
Topkat's Avatar
nope, on the passener side i removed the oil filter bracket but the manif is hitting the edges of the bell housing
Topkat is offline
post #4 of 21 (permalink) Old 02-14-2011, 07:14 PM
jack it up! i would have put them on before putting it in.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #5 of 21 (permalink) Old 02-15-2011, 07:46 AM Thread Starter
Topkat's Avatar
Do I indeed need to raise the motor to get them on?
Should I remove the tranny support bolts?
can I somehow do one side at a time without having to remove both motor mount bolts at the same time?
thanks as always
Topkat is offline
post #6 of 21 (permalink) Old 02-15-2011, 09:38 AM
yes. they should have been installed with the engine.
freethinker is offline
post #7 of 21 (permalink) Old 02-15-2011, 10:03 AM
thanks as always
Do the passenger side first. Remove the long motor mount bolt just on that side, then use a jack to lift that side of the motor up to get room. Put the manifold on and start the bolts (you don't have to tighten them yet). Drop the passenger side, re-install the motor mount bolt, then repeat the same process on the drivers side (remove the bolt, lift, install, drop and re-install the bolt). Once you're happy everything looks good and is lined up, tighten up the exhaust manifold bolts on both sides.
You shouldn't have to loosen the tranny mount or anything else --- there's enough give in the rubber mounts to let things move enough.
Tip: Put a goodly amount of anti-seize compound on all the manifold bolts, and everthing that bolts to the manifolds (like the head pipes). You'll be glad you did if you ever have to remove them again.
post #8 of 21 (permalink) Old 02-16-2011, 11:10 AM Thread Starter
Topkat's Avatar
thanks Bear.
took me longer to assemble and disammemble the hoist then to get them both in...
Topkat is offline
post #9 of 21 (permalink) Old 02-16-2011, 11:54 AM
You're welcome sir. Those are nice looking manifolds. I'm curious to hear how you like them once you get the car going.
post #10 of 21 (permalink) Old 02-16-2011, 06:55 PM Thread Starter
Topkat's Avatar
On the passenger side ex manif, the second bolt from the rear, the roundness of the metal is so close to the hole I cannot get a bolt in it. However the hole is bigger than the others. I tried cutting one of the 3/8'' bolts really short, with the idea of inserting it in "sideways' that didn't work either.
I may be able to put a stud down thru the top of the head to ex manif hole and nut the bottom.
Has anyone dealt with this?
thanks as always
Topkat is offline
exhaust manifolds Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 11-17-2010 11:54 AM
pontiac manifolds scy-co 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-07-2010 12:33 AM
LS2 intake manifolds? GTO_06 Intake and Exhaust Discussions 9 09-25-2009 07:18 PM
Exhaust Manifolds texasgto 2004-2006 GTO General Discussion 1 02-22-2005 11:36 AM
