Hey all I have a 1970 Lemans with 350/350 combo bought from a junkyard and here is what I know and what I think I know.
Stock lower end w/ a mild cam (I think it has a mild cam because anything under 10deg of timing causes it to back fire out the carb)
Heads have been rebuilt and still uses stock parts, rockers torqued to 20ftlbs
Here is where it gets dicey I have a tomahawk single plane manifold with a 1406 eddy sitting on a 1in spacer, no power brakes.
my ignition is a MSD pro billet with no vacuum advance I have found it runs happiest at 14 degrees advanced and pulls 15 on a vacuum gauge.
It runs and drives great but a little sluggish off the line with a 2.73? open diff my concern is the MPG it gets about 11 about half freeway driving. Would my mismatch of parts cause this? It gets 89 octane in cali gas. The carb is set with the number 8 tuning chart mixture which leans it out some. This car was built on a vary tight budget.
Forgot to mention exhaust, stock manifolds running dual exhaust 2.5 with thrush mufflers no X/H pipe
thanks for the replys I want to toss on a vacuum advance dizzy just for giggles, The intake was cheap so it went on, replacing a warped eddy p4b intake.
Well I have been reading around that some people are getting around 15-20 mpg I would be happy with 14, I am not looking for a miracle, just an improvement. Honestly that would almost put it on par with my truck and I could use them interchangeably, as this car may not be the fastest or prettiest but it is mine and I enjoy it to much to let it sit around :smile3:
Thanks for the tips advice all! A little update I did try the 1425 primary jets which are .72 and I was getting a miss under light throttle, I fixed that by going to a 70x37 rod vs the 73x42 that had been in there. Pump shot is on the top hole. While it does run great question is did the smaller rods negate any mpg improvement that the smaller jets provide?
Maybe I just have to save my pennies and stop trying to make my current set up economical lol
Update time, I am going to freshen up the cars original points distributor and run that for now and maybe down the road try the pertronix igniter conversion. This raised a new question for me however, can I run the original points to an MSD blaster II coil with a 6Al box? I have read that yes I can but I would like to hear from the experts. Thank you all for the support and input learning as I go.
Yes you can.IIRC the white wire on the MSD box is the points trigger wire.
Related Threads
Pontiac GTO Forum
514K posts
38.4K members
Since 2004
