Fan shrouds - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-05-2013, 01:38 PM Thread Starter
Fan shrouds
In my quest to get my 67 running cool I need to make a few corrections to the cooling system. Years ago I purchased a "factory correct replacement" fan shroud that never fit right, and being a dumb kid I cut it up to make it fit but it has never been right. In the interest of getting it right this time I was wanting to hear from a few of you that may have recently purchased a replacement fan shroud; was the fit correct? Did the fan sit centered in the opening? Did it bolt up right? Did you need a spacer to get the stock fan positioned correctly? Where did you purchase yours?
67 AT w/o air, stock clutch fan
Thanks!
Yes I did a search first
noahfecks is offline
post #2 of 6 (permalink) Old 08-05-2013, 06:08 PM
in what way is your replacement not fitting right?
OhioLS2 is offline
post #3 of 6 (permalink) Old 08-05-2013, 10:34 PM Thread Starter
It has been 15-20 yrs since I purchased the replacement, cant even remember where I got it. The top and bottom hit the caps and didnt allow the rest of the shroud to sit up against the core, also the fan was off center in the opening, and the opening sat too far from the engine necessitating a spacer. What is wrong with the replacement that I hacked up as a kid isn't really my concern at this point, I just want to know what other people with recent experience have found that does work. The purchase of a new shroud is a necessity at this point so I would like to make an informed/wise selection. :beer:
post #4 of 6 (permalink) Old 08-06-2013, 07:44 AM
SANDU002's Avatar
I recently fixed the cooling problem on my 67 AT w/o air. My shroud was pretty new so didn't need to replace that. After measuring the shroud inside dimensions, I purchased a new 18" clutch fan from Performance Years. Got everything including hardware kit and was an easy install. Also put in a new 180 degree thermostat. Then I drove the car 1,000 miles to nationals and back and had no heat issues. Car ran at 200 on highway and 210 - 215 around town.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #5 of 6 (permalink) Old 08-06-2013, 12:05 PM
Quoted: 102 Post(s)
I got a shroud from OPG for my '67 with no AC but with the 4 row radiator. It bolted on in minutes with no modifications. Perfect fit. I got it for $59 on sale with free shipping. A lot of the early repop shrouds were fiberglass and were pretty rough and ill-fitting. The new plastic stuff seems to work well. As a side note, never use a spacer with a fan clutch type fan. You will eat water pumps.
post #6 of 6 (permalink) Old 08-06-2013, 02:54 PM Thread Starter
Thanks! This is exactly the kind of info I am looking for!
Fan and Fan Clutch jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-14-2012 02:07 PM
Clearance between Radiator Fan shroud and fan jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-22-2012 04:51 PM
fan and fan clutch Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-20-2011 09:09 AM
never been a fan of white 58mark 1964-1974 Tempest, Lemans & GTO General Discussion 17 12-01-2010 02:35 AM
Spark Plug Shrouds hoggmadd Intake and Exhaust Discussions 2 08-05-2010 02:23 PM
