finally got some work done - Pontiac GTO Forum
post #1 of 13 (permalink) Old 03-28-2011, 02:03 PM Thread Starter
Got this 67 in Feb., drove it 10 miles to get gas then started taking it apart. Slow progress since the weather here (Mo.) has not been that great but its coming along.
ID:	10672   Click image for larger version
ID:	10673   Click image for larger version
ID:	10674   Click image for larger version
ID:	10675   Click image for larger version
6tee7 is offline
post #2 of 13 (permalink) Old 03-28-2011, 03:08 PM
Nice work!
post #3 of 13 (permalink) Old 03-28-2011, 05:03 PM Thread Starter
Thanks Bear
6tee7 is offline
post #4 of 13 (permalink) Old 03-28-2011, 07:41 PM
Nice detail job.....looks like it only has 10 miles on it!! Eric
Eric Animal is offline
post #5 of 13 (permalink) Old 03-29-2011, 06:54 AM
jetstang's Avatar
Really nice, I like the Vette master and booster.
I bet it doesnt' have 10 miles since the redo, there is way to much paint on the exhaust ports, and it's not discolored, that won't last..
Burning rubber since 1982!!
jetstang is offline
post #6 of 13 (permalink) Old 03-29-2011, 08:49 AM Thread Starter
Thanks Jet, ur right, 0 miles, still working on front suspension. I converted from manual to disc brakes from Inline Tube, they promised it would work with 14 inch wheels, they said the kit was from a 68 GTO but you are probably right.
6tee7 is offline
post #7 of 13 (permalink) Old 03-29-2011, 09:26 AM
67 Basket Case Restorer
Too Many Projects's Avatar
That is the correct master/booster for a '67. It's the same set-up I got from them for my '67 GTO. Curious if In-Line supplied original 4 piston calipers with that '68 kit, as that is what would be correct. SOME 14" wheels will work with the early disc brakes, but they need to have been built after August '66 for the introduction of the discs on the '67 models.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #8 of 13 (permalink) Old 03-29-2011, 05:44 PM Thread Starter
Too Many, it looks like a single piston about 2 to 2 1/2 in diam.
6tee7 is offline
post #9 of 13 (permalink) Old 03-29-2011, 05:57 PM
I kind of figured they were single piston. That is '69 up and will actually be better than the 4 piston calipers, which were somewhat troublesome. However, the 4 piston disc brakes were an actual option in '67 and are "correct" for your car, if you are concerned about that.
Mitch
1962 Impala SS
1938 Chev coupe
post #10 of 13 (permalink) Old 03-29-2011, 10:13 PM
jetstang's Avatar
Most Drum/Disc combos have dif size front/rear master cylinder volume. Hmm, thought that was Vette only, guess I just don't know. Still looks really nice.
jetstang is offline
will it work? HoldenGTO Engine Discussions 1 11-15-2006 07:54 PM
Anyone know if these will work? CrazyAL Wheels and tires 3 03-29-2006 02:34 PM
Will these work well? putergod Intake and Exhaust Discussions 6 03-24-2006 11:15 AM
Does it work? Sylvia Holden Test Forum 1 02-17-2005 09:28 PM
[Freebies] How they work, why they work & how to work them. Last The Lounge 1 01-09-2005 07:15 PM
