First post! Help me answer a few 67 GTO questions. - Pontiac GTO Forum
post #1 of 14 (permalink) Old 10-23-2011, 08:23 AM Thread Starter
Like I said, this is my first post on this forum, thrilled to have a Goat !
I have purchased a two owner 1967 2 door HT, originally equipped with the 400 HO/ Hurst His/Her automatic. The original 400 is long gone, and now has a 389 in it. My question is, down the road, if I decided to try to locate a 67 400 HO (YZ code I believe) for the GTO, what are the acceptable date variances between car and engine? I realize that it wouldn't be the original numbers matching but could be "correct". Also, what are the chances of finding a YZ code 400, and were they exclusive to GTO's? Thanks in advance.
Goats Rule is offline
post #2 of 14 (permalink) Old 10-23-2011, 09:37 AM
FNG69's Avatar
Welcome to the Place!! You do know we will want to see pictures !! Check date code on the 389 to see if it is a GTO engine might get lucky. With a 2 owner car it may not be to molested. Can you find the 2 owners and check with them, sometimes you get lucky and the engine is still setting in a corner of the garage.Finding a correct # block will be a job. It would need a build date of 2 to 3 weeks within the body date of the car. Then heads, intake date codes must be the same for the block, will you idea. Not impossible just a lot of work. Where you out of??? Les
FNG69 is offline
post #3 of 14 (permalink) Old 10-23-2011, 10:01 AM
Quoted: 103 Post(s)
X2. Depending on which plant it was produced in, engine dates can precede the build date of the vehicle by quite a bit....I would say a month or two. HO blocks are not super common, but I have seen them. Be prepared to pay $$$ for the one you need. You may, however, get lucky. Welcome aboard!!
post #4 of 14 (permalink) Old 10-23-2011, 03:37 PM
Welcome! If you decide to look for a 400 HO we'll help you find one. Do you know which 389 you have now?? E
Eric Animal is offline
post #5 of 14 (permalink) Old 10-23-2011, 07:18 PM Thread Starter
Thanks for the warm welcome. I won't really have any information that would be helpful until I pickup the car next weekend. The second owner (1976 - present) did tell me that the original 400 blew up in the early 90's and was replaced with a freshened up 389 out of what he believed to be a Bonneville. Hopefully the heads, intake, exhaust manifolds, carb, etc. were taken off the 400 and transplanted onto the current mill. He thought that the 389 was as strong if not stronger than the original HO 400. That kind of puzzled me.
I will post pics and have more information in about a week.
post #6 of 14 (permalink) Old 10-23-2011, 09:35 PM
Quoted: 103 Post(s)
Goats, the 389 I have in my '65 GTO was/is stronger than the 428 that preceded it, and will run circles around the 400 in my '67 GTO. It has a bigger cam and more compression, but it has worse heads, less cubes, etc. than the 400. Every 389 I've driven over the years ran very strong. (probably due to high compression). A little old 389 will surprise a lot of folks....especially of the Chevy and Ford variety!!!
post #7 of 14 (permalink) Old 10-25-2011, 03:22 PM Thread Starter
So tell me.....how difficult would it be to find "correct" block, heads, etc? I realize it will never be numbers matching, but how much less is a nice 67 "correct" GTO worth than an original one?
Just trying to figure out the direction I want to take with the car. It has a 389 4 BBL, would be a nice driver as is or I can try to find the "correct" 400 for it. It's a low option 400 HO with his/hers, gold with black vinyl top.
Thanks in advance.
John
post #8 of 14 (permalink) Old 10-25-2011, 04:06 PM
Thanks in advance.
John
I always answer this sort of question with something like this: What are you going to do with the car? If it's for you to enjoy, then who cares what anyone else thinks it's worth? Build it for yourself and have a blast. If you're building it as an investment (i.e. building it for someone else), then as close as possible to original is almost always going to be "worth" more. How much exactly is very difficult to predict - so much depends on the current market and who's buying. Try watching the various collector car auctions on TV and checking web sites that sell classics for "similar" cars to get a ballpark estimate.
post #9 of 14 (permalink) Old 10-25-2011, 06:22 PM
Quoted: 103 Post(s)
I agree with Bear 100%!!!
post #10 of 14 (permalink) Old 10-26-2011, 05:29 AM
These cars are no fun and are completely worthless unless they are 100% matching numbers.
Nothing else matters.
Oh, and Welcome!
can't find the answer 64conv 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 03-22-2011 09:51 PM
Changing GTO post coupe to no-post hardtop jonlazar 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-05-2008 10:53 AM
Please Help Me Answer Some Questions About The GTO FlameofOsiris 2004-2006 GTO General Discussion 22 05-26-2008 04:34 PM
Mythbusters is attempting to answer our favorite questions bg2m8o The Lounge 56 11-14-2007 11:03 PM
someone please answer this!!!!!!! enjracing 2004-2006 GTO General Discussion 4 08-11-2006 12:19 PM
