Foam Seals - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-23-2015, 02:49 PM Thread Starter
Foam Seals
To those that can help. Probably an easy one for those on here but I'm confused. Ok, have an 1968 GTO with the three speed. Aside from an awesome mechanic who helps when I need it most, my experience is limited despite the reading I do on the internet. The foam seal that sits on top of the air filter pan was in terrible shape so I tore it off, cleaned up the adhesive and will install the new one this weekend. Easy. However, I have this Ram Air seal for the hood which I grabbed from Original Parts Group and I don't see how this installs into the upper part of the hood via the air baffle. Is this an integral part for much? I've driven the car for two years without one. If anyone has any information on this I'd greatly appreciate. Just don't know what to do with it.
calicoss is offline
post #2 of 3 (permalink) Old 10-24-2015, 05:15 PM
The 68 ram air system was significantly different from 69 and later. Are you sure what you have on your car? Photos would definitely help.
post #3 of 3 (permalink) Old 10-29-2015, 01:05 PM Thread Starter
BearGFR, thanks for getting back to me on this. I'll take pics this weekend. The foam seal for the top of the air filter pan went in no problem. I had the air baffle off, the part that screws in underside of the hood, and I just can't seem to figure out the fit of the seal. Again, I'll take pics. Thanks for the help
calicoss is offline
Foam on Heater Box Assembly Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-27-2013 10:21 PM
Head rest and seat foam GTOcop 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 04-24-2011 03:58 PM
Sea foam? RMTZ67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2011 11:28 AM
Foam Insulation canadianGTO 2004-2006 GTO General Discussion 1 02-15-2010 01:37 PM
