Front jacking point 67 Lemans - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-16-2013, 08:56 PM Thread Starter
gotyorgoat's Avatar
I plan to remove my transmission tomorrow on my garage floor. What is the proper jacking point at the front? Can I jack under the front crossmember or do I jack up the frame just behind the front wheels? Thanks
It doesn't have nitrous. It has cubic inches.
gotyorgoat is offline
post #2 of 3 (permalink) Old 03-17-2013, 02:13 PM
Quoted: 98 Post(s)
Jack the car up by the front crossmember and then install a jack stand on each side of the frame right behind the front wheels. Higher is better: easier to get a jack under the trans if needed and it allows you more room to work and finesse the trans. Block the rear wheels, also, so it can't roll off the stands since you won't have any parking brake.
post #3 of 3 (permalink) Old 03-17-2013, 03:49 PM Thread Starter
gotyorgoat's Avatar
Thanks for the help.
1966 Lemans 3 Point Seat belts Bensjammin66 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 15 04-24-2015 04:16 PM
67 GTO Jacking Points lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-27-2011 09:10 AM
Jacking the car up rdgerken Service, Maintenance and Technical Discussion 6 10-11-2011 07:03 AM
4 point roll bar in a 67 lemans post? virginiavenom 1964-1974 Tempest, Lemans & GTO General Discussion 5 09-09-2011 07:34 PM
Jacking Points -Revealed!! diverdan Service, Maintenance and Technical Discussion 8 05-20-2005 09:23 AM
