front shock torq - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-11-2011, 04:44 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
front shock torq
I just put in my front shock. The book says 90lbs. (seems like a lot,but ok)
I just cant seem to get there and suspect the shock "rod" is turning.....; I could hold the sucker with vise grips............
Are the dam things supposed to turn?
What to do?
thanks as always
Topkat is offline
post #2 of 6 (permalink) Old 04-11-2011, 06:26 PM
For some reason 35lb sticks in my mind, vice grips would work or an adjustable wrench or a small wrench that fits the shaft end. Just did mine with the car on its tires,dont know if that made any difference but had no problems.
6tee7 is offline
post #3 of 6 (permalink) Old 04-11-2011, 06:30 PM
I always held mine with an adjustable wrench, while using an open end to tighten the nut down....90 lbs sounds a little much.......E
Eric Animal is offline
post #4 of 6 (permalink) Old 04-21-2011, 01:17 AM
likethat's Avatar
I always tighten down till I see the rubber isolators are just a bit fatter then the washer but not squeezing out past at the top
67 GTO H.O. Convert 4spd
likethat is offline
post #5 of 6 (permalink) Old 04-21-2011, 12:50 PM
Yep, that's the way to to it.
post #6 of 6 (permalink) Old 04-21-2011, 02:46 PM
Quoted: 103 Post(s)
I do it like likethat and Bear. Done it thousands of times over my career, probably. 90 lbs torque? Sure, if you want to snap the shock rod in two. More like just snug with the bushings squeezed, as stated. They make a special socket (oval shape) that fits the shock strut. There are two sizes. You should be able to just run the nut down without worrying about it, though.
Front Shock U-Nut Source hookemdevils22 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-23-2010 03:07 PM
Torq Thrust sampsonite Wheels and tires 1 03-17-2009 07:04 PM
Ordered 17x8 Torq-Thrust II wheels. Will they fit ok? Red_Spice Wheels and tires 0 03-17-2009 11:17 AM
