Front Springs - Pontiac GTO Forum
 4Likes
  • 2 Post By PontiacJim
  • 1 Post By tiretread
  • 1 Post By Lemans guy
post #1 of 8 (permalink) Old 02-22-2019, 11:08 PM Thread Starter
69_Custom_S's Avatar
Front Springs
Anyone have any input on cutting the factory springs on the front of 1968-70 gto/ GM-A Body to get a more appealing ride height? My car sits a little high in the front and I would like to lower it a few inches.
69_Custom_S is offline
post #2 of 8 (permalink) Old 02-23-2019, 09:13 AM
Quoted: 404 Post(s)
Seriously? Just purchase the correct height springs and be done with it - no guessing, no car leaning, no bottoming out, and safer.
05GTO and Bobbyg like this.
post #3 of 8 (permalink) Old 02-23-2019, 01:14 PM
1968gto421's Avatar
Quoted: 72 Post(s)
Member Pinion Head supplied this info in an old post:
"Coil Spring Specialties has all the factory spec sheets. These include wire gauge, free length, & number of coils.
CSS can also spec custom coils springs for custom ride heights & for vehicles that have had significant weight removal from the front of the car.
Coil Spring Specialties"
Here's a link to their site: Coil Spring Specialties
Hope this helps.
1968gto421 is offline
post #4 of 8 (permalink) Old 02-23-2019, 10:07 PM
Quoted: 11 Post(s)
05GTO is online now
post #5 of 8 (permalink) Old 02-25-2019, 09:01 AM
Quoted: 9 Post(s)
I bought some springs from Coil Springs Specialties. I had the same issue with the front riding a bit higher than the rear. I haven't put them on yet but the customer service from CSS was great and I would highly recommend talking to them as they were extremely helpful.
1968gto421 likes this.
tiretread is offline
post #6 of 8 (permalink) Old 02-25-2019, 07:50 PM
Lemans guy's Avatar
Quoted: 79 Post(s)
When I replaced the springs on my 1966 Lemans I noticed a difference as well. Now it is not a 70, but here is what happened. I went with stock springs front and rear, this is on a 2 door coupe. The rear sat low and made the front look high. But this was the way the cars did sit back then, lower than a lot of us like them now.
So I changed the rear springs to 66 station wagon springs which are a tad stiffer. It made all the difference, back went up just enough and ride height looks great. I also use mono tube shocks bilstein front and KYB rear ( Bilstein does not make rears for this car) and they help as well.
You can lower the front but you get into lots of issues with alignment, rubbing, ball joint wear etc.
But you have to make it how you want it!!!
Lemans guy is offline
post #7 of 8 (permalink) Old 02-25-2019, 07:52 PM
Lemans guy's Avatar
Quoted: 79 Post(s)
PS... you also want to insure that the springs are correctly in the perch in the A-Arm if not they can ride up on the boss and effect ride height!!!
post #8 of 8 (permalink) Old 02-27-2019, 08:58 PM
You can buy 1 and 2 inch lowering springs cheap on E-bay. Highly recommend this route. Cutting your springs makes them weaker and your car will be bouncing around like a cheap mini truck!
manley66 is offline
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 10:52 PM
Stock Springs VS Lovells Springs GM4life Drive train, suspension, alignment and brakes. 10 06-03-2011 02:16 PM
Front Springs - What brand/spec springs are you running? Jeff's Classics 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 11-26-2010 01:12 PM
big block springs up front Dannyz 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 06-25-2009 09:40 PM
