Front sway bar brackets... - Pontiac GTO Forum
post #1 of 17 (permalink) Old 10-12-2010, 01:22 PM Thread Starter
PisnNapalm's Avatar
So.. Yesterday I met the mechanic who had worked on my car for the previous owner. He had a set of front sway bar brackets the PO had purchased but never had put onto the car.
One of the original brackets had broken and was welded back together. He gave me the brackets for free and now I'd like to get them on the car.
Here are my questions...
Can this be done properly without putting the car on a lift?
Will this procedure affect the alignment?
I believe the bushings are still good.
Thanks again for helping out a noobie.
PisnNapalm is offline
post #2 of 17 (permalink) Old 10-12-2010, 01:40 PM
If you are talking about the "U" shaped bracket that bolts the front sway bar to the chassis: Yes it can be installed with out a lift. i usually place a floor jack under the sway bar near the bracket and pump it up till it just moves the car up a little. Then swap out the part. Eric
Eric Animal is offline
post #3 of 17 (permalink) Old 10-12-2010, 01:59 PM
What's wrong with the brackets on the car now?? Or are you saying the welded one is on the car now and you have new ones to replace them with?
In any case, yes they can be replaced without a lift. Just do one side at a time.
post #4 of 17 (permalink) Old 10-12-2010, 02:07 PM Thread Starter
PisnNapalm's Avatar
Rukee.. One of the brackets on the car was damaged and repaired. I now have two new brackets.
Thanks for the help guys.
post #5 of 17 (permalink) Old 10-12-2010, 03:42 PM Thread Starter
PisnNapalm's Avatar
So... nothing is gonna shift on me when I do this right? Sorry, I'm just a bit paranoid.... or precautious...
post #6 of 17 (permalink) Old 10-12-2010, 05:02 PM
It might move forward or back a bit, but you should have no problem moving it back and getting the bolts started.
post #7 of 17 (permalink) Old 10-13-2010, 06:11 AM
jetstang's Avatar
It shouldn't be hard. I would loosen up the end links on the control arms before trying to swap them out, no reason to fight the end links. Just jack the front of the car up and go for it. The sway bar is attached in 4 obvious spots, loosen it all up and swap the caps. If the center bushings and end links look deteriorated at all, this is a good time to swap to poly bushings, they are available at Autozone or Advanced for $30 for all of them.
If the old cap is in good shape and holding the bushing/bar I would just hold onto the new caps for a later redo.
Burning rubber since 1982!!
jetstang is offline
post #8 of 17 (permalink) Old 10-13-2010, 09:05 AM
Quoted: 117 Post(s)
Don't worry. Your wheel alignment will not be affected.
post #9 of 17 (permalink) Old 10-13-2010, 11:54 AM
If you are just replacing the brackets (not bushings), then I would just support the sway bar against the the frame (as Eric Animal mentions), though this is not critical. If you have a new bushing, it is sometimes a little difficult to get the bolts initially threaded. Once started, the new bushing compresses alot to form a tight hold on the sway bar. If you are using your old bushings, they are likely somewhat formed/compressed, and this will likely not be of any difficulty.
I would not loosen the end-links for this purpose, no need to IMO. Alignment won't be affected.
1970 Lemans is offline
post #10 of 17 (permalink) Old 10-13-2010, 03:41 PM Thread Starter
PisnNapalm's Avatar
Thanks for all the info guys. I'll probably get this over the weekend.
Front sway bar bushings Gremlin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-18-2010 02:09 PM
Rear Sway Bar CTCarGuy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 11-17-2009 04:24 PM
Sway Bar Links? PEKO Drive train, suspension, alignment and brakes. 1 09-07-2007 09:09 AM
Popping noise coming from anti-sway bar on front gtoidiotswitch Drive train, suspension, alignment and brakes. 1 02-13-2006 07:46 AM
Sway bar dgoat4me 2004-2006 GTO General Discussion 6 01-02-2006 06:05 PM
