fuel hose - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-06-2011, 07:35 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
fuel hose
the fuel fitting on my new carb sticks out , and I have a straight fitting going to a rubber fuel line, when the hose is on, it will be up against the upper radiator hose.
(no one has the right size 90 either................)
How big,if any,of a problem is this?
thanks as always
Topkat is offline
post #2 of 5 (permalink) Old 10-06-2011, 07:42 AM
you should try to separate them as the heat will transfer to the fuel hose and could cause vapor lock. Another thing would be to insulate the fuel hose, but separation would be the best.
post #3 of 5 (permalink) Old 10-06-2011, 07:45 AM
If you can't find the proper fitting, and the fuel line must touch the rad hose, secure a small piece of black foam pipe insulation (or the likes there of) to the fuel line for ;1) insulation from heat, and 2) as an anti chafing measure. Eric
Eric Animal is offline
post #4 of 5 (permalink) Old 10-06-2011, 09:01 AM
Quoted: 103 Post(s)
I think the vendors sell the proper outlet line. It's a 90 degree bend to the driver's side. It needs to be there in order not to be "rigged". If you get the right line, you'll be glad you did.
post #5 of 5 (permalink) Old 10-06-2011, 09:09 AM
PVC hose bracket SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-07-2011 08:50 AM
HELP! Engy coolant hose Kurtherogto Engine Discussions 4 02-25-2009 12:01 AM
65 GTO Upper Radiator Hose fst65gto 1964-1974 Tempest, Lemans & GTO General Discussion 12 04-19-2005 06:32 PM
