fuel leak - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-07-2011, 04:43 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
fuel leak
it seems I have fuel leaking from where the fuel fitting goes into the carb and where the reducer fitting meets it.
is it ok to use teflon tape here?
if not what could i use?
thanks as always
Topkat is offline
post #2 of 8 (permalink) Old 10-07-2011, 04:49 PM
Yes you can, but the first fitting into the carb (with the 1" wrench is needed) should have a thin Teflon washer that seals it, then the second fitting should be a flared fitting that seals as it's tightened.
post #3 of 8 (permalink) Old 10-07-2011, 04:55 PM
Quoted: 103 Post(s)
Rukee's right. And, if you get any teflon tape into the fuel inlet, the carb will need to come apart to clear it out of the needle and seat, and maybe the jets. Go REAL EASY on the tape. I prefer not to use it, myself. DId you get the correct angled fuel line that goes from the carb to the filter/pump? Knew a guy back in high school who's '69 Judge burned to the ground because of a rigged fuel line and the resulting fire. Fuel leaks under the hood are not an option.
post #4 of 8 (permalink) Old 10-07-2011, 06:37 PM Thread Starter
Topkat's Avatar
the 9o is on order Uncle G
Topkat is offline
post #5 of 8 (permalink) Old 10-08-2011, 10:07 AM
Quoted: 103 Post(s)
Bless you, TK.
post #6 of 8 (permalink) Old 10-11-2011, 09:16 AM
peahrens's Avatar
I had some issues with my tri-power reinstall last year also. Back in '92, I had used Permatex 98H and I tried that first last year. My recollection is that (a) there's a yellow teflon tape for gasoline/etc that I used where the fitting blocks went into the carbs but that (b) sealants (tape or goo) at the flared fittings is not desireable as it's the flare that must achieve the seal, not the treaded part of the fitting that presses the flare to its seat. A tricky part is tightening enough to get a seal and also getting the angle so the fuel line lines up. And, yes, some connections have gaskets/etc; e.g., the big fitting to my cengter carb. Anyway, it's great when you finally succeed.
It worked for me as my problems were at the threaded blcok-to-carb points. I do believe someone objected to the teflon, but not sure.
BTW, I've established a habit of opening the hood after each drive, to help things cool but also to check for any leak that might be developing.
peahrens is offline
post #7 of 8 (permalink) Old 10-11-2011, 04:59 PM Thread Starter
Topkat's Avatar
Cool......got the correct fitting......... zero leaks.
and NO TAPE!
so nice when ya got the right stuff.
Topkat is offline
post #8 of 8 (permalink) Old 10-11-2011, 05:01 PM
gas leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-08-2011 11:37 AM
leak 04blueskys Drive train, suspension, alignment and brakes. 1 03-20-2011 02:33 PM
HELP! Fuel leak Flyboy 1964-1974 Tempest, Lemans & GTO General Discussion 6 12-11-2009 03:08 PM
Braided fuel line, does it leak? 72GTORed 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 10-23-2009 11:58 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
