fuel sending unit question? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-15-2009, 09:47 PM Thread Starter
Is there a big differance in changing a 3/8/inlet w/ 1/4" return sending unit on my 67 lemans with a/c, changing it to a 3/8" inlet w/o return line? does anyone see a problem, or future problems with it or would a 5/16" inlet work any better, or just replace it what was original? thanks for any help! Thanks Johnconfused
67 Lemans John is offline
post #2 of 2 (permalink) Old 11-16-2009, 07:29 AM
You should be able to replace it with the 3/8" w/o the return line, but you should change the fuel pump to the one without the return line as well. Or just put the original 5/16' one back in. The only reason to swap to the larger one would be if you are running out of fuel at WOT.
A.C. car fuel sending unit asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2008 12:07 PM
What is the differance fuel sending unit 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-22-2008 03:49 PM
Question: Fuel sending unit 1967 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-18-2008 07:27 AM
Choke problem? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 21 06-07-2007 09:21 PM
Computer guages (Autotap OBDII-CAN Diagnostic) MJGTOWISH 2004-2006 GTO General Discussion 3 12-03-2006 10:01 AM
