Fuel tank care? Winterization - Pontiac GTO Forum
post #1 of 11 (permalink) Old 11-11-2011, 06:32 AM Thread Starter
ct66gto's Avatar
First of all -- Happy Veteran's Day and Thank YOU, to every Vet!
Tried a search (for the record) w/o success so, here goes:
Through no choice of my own, I am going to have to park my '66 for at least 3-4 months this winter (can't / won't drive if there is even a chance of roadsalt, anyway).
I have been running her just fine on the highest octane gas I can buy at the pump, without any fuel (lead) 'additive'; however; there is still obviously ethanol in what I have been using.
How do you store ('winterize') your car / fuel system long term?
A buddy suggested an approriate amount of Marine Formula STA-BIL which is what I use on small engines with success but, this is an ALL ORIGINAL 389 tri-power. I am not exxagerating when I say ALL original, either and therefore; I don't want to take any stupid chances . . .
Thanks in advance, this forum and the expertise of the members really does rock!
ct66gto is offline
post #2 of 11 (permalink) Old 11-11-2011, 06:58 AM
SANDU002's Avatar
Fill her up and add the appropriate amount of regular Sta-bil and she will be fine. By regular Sta-bil, I am referring to what you buy off the shelf at any auto parts store.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 11 (permalink) Old 11-11-2011, 08:29 AM
kilkm68's Avatar
I always take her to the gas station, add the appropriate amount of sta-bil then fill the tank to the brim to keep as much condensation as possible out of the tank. I then drive home to circulate the sta-bil through the fuel system then finally dump some sta-bil right down the carb then shut her off for the winter. Been doing this or a long time, never a problem with rancid gas or gum in the carb. Fires right up in the spring, smokes a little till you get the old gas burnt out, I usually burn 1/2 the tank then fill it with fresh preimum fuel, runs great. Wish I didn't have to put her away for the winter either, but it's part of life in this part of the country.
kilkm68 is offline
post #4 of 11 (permalink) Old 11-11-2011, 09:58 AM
I will drive mine in the winter when the weather allows. I do put stabil in the gas tank along with HEET (gasline anti-freeze and water remover). Will run the car & motor to mix. I will use the gas in the tank all winter then in the spring I will add more HEET and go put fresh gas in.
post #5 of 11 (permalink) Old 11-12-2011, 02:42 PM Thread Starter
ct66gto's Avatar
SANDU002, kilkm68, GTO JUDGE, thank you all! I didn't want to seem overly 'obsessive'; however; I have heard some pretty horrific stories about gas with ethanol, etc in it, after it gets too old, etc. No way I want to risk anything with this original 389. Thanks again for your time and assist!
ct66gto is offline
post #6 of 11 (permalink) Old 11-13-2011, 08:40 PM
Same here - stabilizer and a full tank is all I've ever done and have never had any issues.
Kevin's Homepage
1970 Pontiac GTO
Orbit Orange Judge Re-creation / YZ RAIII 400 / M21 4-Speed
1985 Chevrolet Monte Carlo SS
5.7 LITRE / TES Headers / SShaker Hood / WCT5 5-Speed
85_SS is offline
post #7 of 11 (permalink) Old 11-19-2011, 10:28 AM
Beef 66's Avatar
Another follow up question regarding storage. Would you recommend disconnecting the battery? I am looking to rent an indoor storage locker for the winter so I can free up my garage for my truck.
http://i802.photobucket.com/albums/yy308/lawdog31/Victoria/CIMG2349-1-1-1.jpg
Beef 66 is offline
post #8 of 11 (permalink) Old 11-19-2011, 10:36 AM
Yes, definitely disconnect the battery. Check with the storage place as they may actually require that you remove it altogether. When I used to store the Monte, the insurance required all cars to remove their batteries due to fire hazard.
Kevin's Homepage
1970 Pontiac GTO
85_SS is offline
post #9 of 11 (permalink) Old 11-20-2011, 12:50 AM
actually, most storage units that are enclosed and are for storage require less than 1/4 tank (prefer empty) due to fire laws and the storage unit property insurance. (if you ask them about it)
pontiac is offline
post #10 of 11 (permalink) Old 11-20-2011, 12:59 AM
no reason to add HEET (more alcohol) to the gasoline if it already contains 10% ethanol. that is enough alcohol to absorb all the water condensation by itself.
pontiac is offline
grinding around fuel tank area should i remove tank ? fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-08-2011 08:12 PM
fuel tank Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-09-2011 10:26 AM
66 gto fuel tank johnnylightning03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-13-2009 10:03 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
