gas question for a new owner - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-29-2011, 06:39 PM Thread Starter
my66's Avatar
Just got the 66 Lemans. In 66 they still had Leaded gas. What gas should I be putting in my 67 400 GTO tripower? I knoiw they used to have a lead additives to put into the tanks when they went to unleaded gas. Is this still a good aproach? or is the unleaded ok to run?
my66 is offline
post #2 of 2 (permalink) Old 04-29-2011, 07:09 PM
Quoted: 23 Post(s)
the lead is not a factor as much as the octane of today camel piss is. really depends on how long ago and how your engine was re-built and what head casting you have (Compression Ratio). optimal comp. of 9.5:1 to be able to run the swill they pass of as pump gas (89-93). out of the factory most of the pre 71' cars were more like 10.5:1 and would require 96+ octane in today's gas to ward off detonation. If it was rebuilt recently it may have had pistons dished or have larger chamber cylinder heads swapped to it to lower the compression. What gas are you running currently? Do you hear any spark knock (detonation), especially under load (going uphill)if you do you need to run a higher octane.
Instg8ter is offline
Gas tank fuel line / pump question 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-05-2010 09:36 AM
68 gas tank Question jback 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-08-2010 01:38 PM
Compression / pump gas question 67lemans 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-06-2010 12:17 PM
newby question - myserious vaccum line from gas tank GroundHog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-09-2010 07:15 PM
Gas Tank Size Question Rusty Service, Maintenance and Technical Discussion 7 04-20-2007 01:37 PM
