Gas Tank Fuel Line Connections - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-02-2012, 11:27 AM Thread Starter
Jim
Jim's Avatar
On the Gas Tank Fuel line connections, there are two connection, One is supply and the other is return (?). As you look at the connections one is at 6 o'clock the the other is at 3 o'clock. Which one is the supply?
Thanks for the input.
Jim
Jim is offline
post #2 of 5 (permalink) Old 04-02-2012, 11:28 AM Thread Starter
Jim
Jim's Avatar
Btw 67 gto
Jim is offline
post #3 of 5 (permalink) Old 04-18-2012, 06:36 PM
I believe the 3 o'clock is the feed. Can you pull the whole housing apart and look?
etewald is offline
post #4 of 5 (permalink) Old 04-18-2012, 09:56 PM
gotyorgoat's Avatar
Are they both the same size? The bigger one is the supply.
gotyorgoat is offline
post #5 of 5 (permalink) Old 04-20-2012, 10:43 AM
always the bigger one is supply.
pontiac is offline
grinding around fuel tank area should i remove tank ? fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-08-2011 08:12 PM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
Gas tank fuel line / pump question 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-05-2010 09:36 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
