Gauge light problems...... - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-25-2010, 05:26 PM Thread Starter
I had a problem with starting my car and i replaced the neutral safety switch and that fixed the problem. I really didn't mess with any of the wiring around the interior part of the steering column, but the gauge lights will not come on now. Does anyone have an idea what to check to get them working. I am not sure if it is a fuse or not, but any suggestions would help.
Eshack80 is offline
post #2 of 6 (permalink) Old 09-25-2010, 05:33 PM
What year car, model and is it column shift or floor shift ?
Eric Animal is offline
post #3 of 6 (permalink) Old 09-25-2010, 05:44 PM
Quoted: 118 Post(s)
The gauge lights are controlled through a rheostat on the headlight switch. Be sure that the switch is turned clockwise for the gauge lights to come on. They can be turned on and off, and dimmed according to switch position. You may have a switch turned off, or a connector might have become unplugged.
post #4 of 6 (permalink) Old 09-25-2010, 05:50 PM
Or a blown fuse, bad ground or bad connection at the steering column plug. My bet is fuse. Hi Jeff!
post #5 of 6 (permalink) Old 09-26-2010, 11:09 AM Thread Starter
It is an automatic transmission (floor shifter) 69 GTO.
Eshack80 is offline
post #6 of 6 (permalink) Old 09-28-2010, 01:09 PM
Quoted: 118 Post(s)
If you put a blower on it like Eric is doing, you'll be so busy trying to keep it on the road you won't have TIME to look at your gauges and wonder why the lights don't work!!!
3 or 4 gauge A-pillar gauge pod 06BlazinGTO 2004-2006 GTO General Discussion 2 07-31-2011 08:57 PM
2004 pontiac fog light problems please help killacali23 Service, Maintenance and Technical Discussion 1 09-23-2010 11:46 AM
Cluster Low Temp Light / Shift Light GTOJer Interior Discussions 5 10-08-2009 07:32 PM
Tail Light Assy Problems Shorty29 Exterior Discussions 0 09-16-2009 08:31 PM
fuel pressure gauge & boost gauge sdgoat Service, Maintenance and Technical Discussion 4 05-12-2006 09:34 AM
