Generator light question - Pontiac GTO Forum
post #1 of 10 (permalink) Old 11-26-2010, 04:24 PM Thread Starter
The generator light is coming on while I am driving. The voltage and battery has been running over 16 volts, I then replaced the voltage regulator. But I am still having the same problem with the light staying on.
Does anyone have any ideas or suggestions?
Greatly appreciated Thanks!
-Dave
djn789 is offline
post #2 of 10 (permalink) Old 11-26-2010, 04:58 PM
Could be a bad connection at the ignition switch, a bad connection at the alternator, or.....another bad regulator. the wire from the "A" terminal on the ignition switch is a resistance wire. WHAT YEAR CAR DO YOU HAVE???
Eric Animal is offline
post #3 of 10 (permalink) Old 11-26-2010, 09:58 PM Thread Starter
djn789 is offline
post #4 of 10 (permalink) Old 11-27-2010, 01:15 AM
It could also be a lack of grounding on the voltage regulator case,
05GTO is offline
post #5 of 10 (permalink) Old 11-27-2010, 07:22 AM
Ah yes, the infamous grounding issue! make sure ALL the proper parts have a good ground. Also check the VR plug and the harness bulkhead connector for a good connection........Hey Randy!......First thing to do is make sure your ALT is putting out !
post #6 of 10 (permalink) Old 11-27-2010, 05:56 PM
-Dave
He probably has a bad clamping circuit in the VR driving the stator voltage too high, I purchased 4 VR's for the 66 until I found one that worked.
05GTO is offline
post #7 of 10 (permalink) Old 11-27-2010, 10:34 PM
Yep! Similar thing happened to a friend of mine. And most recently my engine guy put 3 starters in a Firebird before he got a good one!!!!!!!! Things ain't what they used to be! E
post #8 of 10 (permalink) Old 11-28-2010, 07:55 AM Thread Starter
Thanks for all the help guys! I found a bad connector at the voltage regulator plug. I finally got a good VR on my 3rd try. Autozone I have had that problem with Autozone before when I bought a headlight switch and it was broken as well.
I got the right voltage reading now however the indicator light is still on. after looking at the wiring diagram I believe that traces back to the ignition switch.
I would like to replace that switch but I can't find one online, and Ames Performance and OPGI don't sell one either.
Does anyone know a place where i can buy an ignition switch?
djn789 is offline
post #9 of 10 (permalink) Old 11-28-2010, 08:14 AM
i doubt its the ignition switch.
freethinker is offline
post #10 of 10 (permalink) Old 11-28-2010, 05:00 PM
It could be the CONNECTION at the ignition switch.
Fog light question MikeTheDiabetic Exterior Discussions 8 04-15-2010 12:32 PM
Generator light firecatsrt 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-28-2009 02:24 PM
Generator Light Problem worldrocker77 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-10-2009 09:11 AM
RE: Generator Update PDQ GTO The Lounge 9 06-26-2008 12:19 PM
new timing light new question 70gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-27-2008 11:23 AM
