Going to see a goat. - Pontiac GTO Forum
post #1 of 19 (permalink) Old 03-25-2011, 01:09 AM Thread Starter
I'm going to look at a '69 GTO with a numbers matching 400 with a 3 speed auto column shifter, I've always had a passion for pontiacs but recently I've been come down with the great one fever. Just wondering if there are any common rust locations to check with the GTO and anything else I should know, thanks.
Moffman is offline
post #2 of 19 (permalink) Old 03-25-2011, 09:41 AM
jetstang's Avatar
Front bottom of rear quarters, rocker boxes, bottom rear of fenders and most important, the fill panel between the trunk and rear window. I had to replace the fill panel on my 66 and 70, the window lip holds water and rusts out. Take a magnet to the fill panel, repairable, but not cheap and you have to pull the rear window. I'm talking about clean southern cars, not northern cars. On Northern cars, the whole car is suspect.
Good luck, and welcome!
Burning rubber since 1982!!
jetstang is offline
post #3 of 19 (permalink) Old 03-25-2011, 09:55 AM
+ check the frame where it kicks down and out in front under the cowl.
bottoms of the doors (inside and underneath) and the same for the trunk lid. GL!
post #4 of 19 (permalink) Old 03-25-2011, 07:49 PM Thread Starter
Thanks guys will do.
Moffman is offline
post #5 of 19 (permalink) Old 03-26-2011, 12:22 AM Thread Starter
Still waiting on VIN, though its in the back of my head it might be a lemans clone. What do you guys think?
Moffman is offline
post #6 of 19 (permalink) Old 03-26-2011, 12:35 AM
skapegoat's Avatar
Cowl tag should say also. I would request phs docs first, that way you know exactly what options and car you are getting.
some may say i have too many projects
skapegoat is offline
post #7 of 19 (permalink) Old 03-26-2011, 12:40 AM Thread Starter
Problem is this guy wants only 7k for it, so its flying away from my hands
Moffman is offline
post #8 of 19 (permalink) Old 03-26-2011, 09:18 AM
skapegoat's Avatar
I think there should be a vin on a blue paper with plastic covering it below the latch on the drivers door.
post #9 of 19 (permalink) Old 03-26-2011, 04:41 PM
I am sure there is better advice from more knowledgeable Pontiac owners.I take it that you already looked at the car and like it.Like the other members said check around the front and rear windows sometimes not visible from the outside due too good body work.I would look in the trunk area and under the dash area and smell the interior for a musty (moldy) smell.Check the frame for sure especially around the body mounts.Check the body to check for excess bondo.As for numbers a real GTO will have the vin starting with 242 that is not saying he put a GTO badge on a Lemans body.Numbers numbers numbers?These cars are old and most of the components have been changed once and maybe several times.All we can tell is the year that different components came from.I own a 69 GTO with a 1969 motor and transmission ( original who knows).Good Luck!!!!
la_belle_fermier is offline
post #10 of 19 (permalink) Old 03-26-2011, 05:58 PM Thread Starter
Actually I haven't its a bit of a drive, and I'm still not sure about it, it seems somewhat fishy especially the price, but who knows.
Moffman is offline
First time at drags, Stang vs Goat, Goat wins... toggles Racing and Kill Forum 7 04-20-2010 11:02 AM
06 modded Goat vs. 04 stock Goat vs. Nissan 240 SX turbocharged dustyminpin Racing and Kill Forum 16 11-09-2009 10:16 AM
bird fought the goat, and the goat won dustyminpin 2004-2006 GTO General Discussion 2 11-13-2006 04:54 PM
