gremlins I tell you - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-23-2015, 06:46 PM Thread Starter
maktope's Avatar
gremlins I tell you
So day one of car back power master starter fails from heat soak. Few electical issues still stemming from who ever rewired the car before I got it. Got the fuel gage and temp gage to work, still can't get oil pressure to work. Giving up and installing an after market cluster for oil fuel pressure and volts under dash. Got permission from a developer who is tearing down old military housing to tear up the roads a bit so mechanic met me went to test out trans break upon launch fuel pump fails. Needless to say car is back in shop. Holly customer support great new fuel pump will be here monday. Power master not so much have my old starter in there for now. Might bite the bullet and rental wire the whole car.
maktope is offline
post #2 of 3 (permalink) Old 08-23-2015, 08:07 PM
Quoted: 390 Post(s)
Well that sucks. I went with the RobbMc mini starter that Bear recommended and uses. I did not get the extra priced nose support plate, so I may be playing with fire because if it backfires while engaged, it can break the starter. I can have it added at any time, and it really isn't much, but I figured I payed enough for it already and shouldn't have any reason for "kick back." RobbMc Performance Products - Pontiac Starter
It's always something, eventually you'll get all the bugs worked out.........and by that time your engine will be due another rebuild because if your luck is like mine, you never get all the bugs worked out. LOL
post #3 of 3 (permalink) Old 08-24-2015, 07:57 AM
I would recommend a mechanical oil pressure gauge. JMO.
Electrical gremlins in my 65 foreevergoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-29-2013 01:02 PM
Gremlins in my GTO? antirice Interior Discussions 1 08-27-2012 01:28 PM
Electrical Gremlins? Khammy87 Interior Discussions 6 01-26-2011 06:21 PM
Elecrical Gremlins Flyboy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-26-2009 03:45 PM
Electrical gremlins kllrvet 2004-2006 GTO General Discussion 19 09-25-2005 11:24 PM
