grinding around fuel tank area should i remove tank ? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-06-2011, 03:12 PM Thread Starter
fiesta62's Avatar
hi, i have some light surface rust around the rear end , i plan on using a wire brush wheel on a drill to clean up the areas before i treat and paint up the spots, but i am thinking there could be some sparks from the grinding, should i remove fuel tank?......and if i should remove tank any tips i need to know before i start to remove it ?....thanks
fiesta62 is offline
post #2 of 8 (permalink) Old 11-06-2011, 03:39 PM
Tambo's Avatar
Should be OK if you can't smell petrol fumes. Its the vapour that causes the explosion.
Tambo is offline
post #3 of 8 (permalink) Old 11-06-2011, 04:33 PM
crustysack's Avatar
If you cant smell gas and as long as you are not grinding ON the tank no problem. If you need to drop the tank drain it first- siphon the gas into a gascan- it will make it so much easier to handle
crustysack is offline
post #4 of 8 (permalink) Old 11-06-2011, 04:47 PM
Quoted: 102 Post(s)
Use a bronze or brass wire brush and you can't get any sparks that way. They sell them the same places they sell the steel ones.... You can also use a fiber brush.
post #5 of 8 (permalink) Old 11-06-2011, 10:50 PM Thread Starter
fiesta62's Avatar
hi gee, ok brass dont spark i didnt know that, but after thinking about it i may as well remove tank and get better access to the areas, i will be able to clean up all the areas above tank too so may as well take tank out, not sure how difficult that is but i assume shouldnt be too hard, thanks
fiesta62 is offline
post #6 of 8 (permalink) Old 11-07-2011, 07:42 AM
VERY True bronze and brass don't spark! They will generate heat by friction.....but not enoug to blow you or your GTO up!!
Eric Animal is offline
post #7 of 8 (permalink) Old 11-07-2011, 08:34 AM
68greengoat's Avatar
It's not hard, just bulky/awkward. As been mentioned, get as much gas out of it as you can to get rid of some weight. If you don't have an extra pair of hands, you may want to use a floor jack and a 2x6 or similar to help steady the tank when taking the nuts off for the tank straps. Lower it a little to disconnect sending unit wire, ground and fuel line.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #8 of 8 (permalink) Old 11-08-2011, 08:12 PM Thread Starter
fiesta62's Avatar
ok great, thanks everyone the tank is coming out....
fiesta62 is offline
fuel tank Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-09-2011 10:26 AM
66 gto fuel tank johnnylightning03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-13-2009 10:03 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
Fuel Tank Placement Don 2004-2006 GTO General Discussion 13 07-26-2006 11:16 AM
Fuel Tank relocation? jasonblair 2004-2006 GTO General Discussion 0 11-24-2004 08:43 PM
