is it a gto - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-09-2014, 07:38 PM Thread Starter
is it a gto
the plate numbers are 65 23737 body bf287 trim 215-24 acc 1113
body by fisher
9A Pontiac, Michigan 5
is this a gto or lemans gto??
pamaedgto is offline
post #2 of 7 (permalink) Old 05-09-2014, 09:32 PM
Roger that's Avatar
Your car is a Fremont, Ca built 1965 Lemans 2 door hardtop coupe with Gold interior built on the 1st week of September.
The GTO in 1965 was an option on the Lemans series. The only way you will know if your car is a true GTO is to get a PHS (Pontiac Historical Society) paper work search. PHS has a website to request your search.
Roger that is offline
post #3 of 7 (permalink) Old 05-09-2014, 09:36 PM
jmt455's Avatar
The only way to be sure (if you don't have the build sheet) is to get the PHS documentation for the car.
PHS Historic Services
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 7 (permalink) Old 05-10-2014, 06:54 AM
SANDU002's Avatar
It is a Lemans. In 1965 the Pontiac plant was one of only two plants that designated the GTO with the code of 5N on the data plate on the firewall. As stated before, PHS will give you all your answers.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #5 of 7 (permalink) Old 05-10-2014, 08:42 AM
Roger that's Avatar
The 5N (code for GTO) was used in the Pontiac plant (PON) and the Kansas plant (KAN). The cowl tag in question though is from Fremont, CA (BF).
post #6 of 7 (permalink) Old 05-10-2014, 09:11 AM
Also, Fremont was the only plant that used The UPC coding system the OP listed above, The car was an early production built the first week of September 1964 and was the 287th Tempest, Lemans or GTO built in Fremont.
acc 1113
05GTO is offline
post #7 of 7 (permalink) Old 05-10-2014, 09:25 AM
Quoted: 118 Post(s)
I'll third that. Need the PHS to confirm, as the 5N thing does not apply to many '65 GTO's.
