Harmonic Balancer? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 05-08-2011, 09:39 AM Thread Starter
SWOOSH's Avatar
Harmonic Balancer?
Can you tell me how to get the Harmonic Balancer bolt loose? Right or left hand threads? Any suggestions like torch,cheater bars. I tried an impact both directions and it won't loosen. Thanks!
SWOOSH is offline
post #2 of 9 (permalink) Old 05-08-2011, 10:07 AM
FNG69's Avatar
Is the engine turning with you might have to pull the pulleys then put pulleys bolts back in and a cross brace on them to stop that. It's just standard threads, right on left off..
FNG69 is offline
post #3 of 9 (permalink) Old 05-08-2011, 10:16 AM
Conventional threads. Use a cheater bar on a 1/2" breaker bar and a six point socket.
post #4 of 9 (permalink) Old 05-08-2011, 11:31 AM
Quoted: 118 Post(s)
You can wedge the breaker bar against the ground and hit the starter really quickly. It'll break loose easily. Not real professional, but it will work...
post #5 of 9 (permalink) Old 05-08-2011, 04:20 PM Thread Starter
SWOOSH's Avatar
OMG!!!!!! I put a long cheater bar on the bolt and put it near the ground. Then I hit the starter and the cheater bar rotated around and tore thru my new GTO hood. ^*#@$&#**!
SWOOSH is offline
post #6 of 9 (permalink) Old 05-08-2011, 04:22 PM Thread Starter
SWOOSH's Avatar
Man!!!!!!!!! I just about died writing that. LMAO! Sorry couldn't resist.Thanks for your suggestions guys.
SWOOSH is offline
post #7 of 9 (permalink) Old 05-08-2011, 04:56 PM Thread Starter
SWOOSH's Avatar
I blocked the crankshaft from turning and used a 5 ft cheater. Worked great!
Thanks!
SWOOSH is offline
post #8 of 9 (permalink) Old 05-08-2011, 10:50 PM
FNG69's Avatar
You're having to much FUN!!!!!!!!! Thanks for the update good to hear you got her done!!!!!!!!
FNG69 is offline
post #9 of 9 (permalink) Old 05-09-2011, 06:50 PM
Quoted: 118 Post(s)
It would have been ALL MY FAULT!!! That's ok....it wouldn't be the first time!!!!
Harmonic Balancer YellO5LS2 Engine Discussions 1 01-20-2011 09:33 PM
65 389 harmonic balancer torpedo51 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-02-2010 11:50 PM
harmonic balancer 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-27-2010 01:30 AM
How to remove the Harmonic Balancer Joust 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-14-2009 08:56 PM
