Hazard Switch - Pontiac GTO Forum
post #1 of 7 (permalink) Old 10-27-2014, 07:30 AM Thread Starter
Hazard Switch
I bought a 65 GTO with a Non-tilt steering wheel. After rewiring the whole car I traced a blinker problem to a hatchet job done to the wiring in the steering column. The problem is I have no idea where the hazard button should be. Is there anyone that can help with this. I don't even know if this is the correct steering column for this car. A picture would be awesome!!
1965gto is offline
post #2 of 7 (permalink) Old 10-27-2014, 08:16 AM
allpawl66's Avatar
65 had no hazard button . I have a column if needed in Pa.
allpawl66 is offline
post #3 of 7 (permalink) Old 10-27-2014, 09:22 AM Thread Starter
Thanks I guess I didn't miss it. I was going crazy trying to find that switch because the American Autowire has a pin out for it.
Thanks about the steering column also but this one is fine, they just cut the turn signal wiring, twisted them back together and electrical taped them. Classy wiring job
1965gto is offline
post #4 of 7 (permalink) Old 10-29-2014, 06:53 PM
666bbl is offline
post #5 of 7 (permalink) Old 10-29-2014, 08:39 PM
Originally Posted by 666bbl View Post
It is listed in the restoration guide as well;
Name:	hazard light.jpg
05GTO is online now
post #6 of 7 (permalink) Old 10-30-2014, 10:13 AM
Quoted: 5 Post(s)
for what it's worth, the Dakota Digital gauges I installed will start flashing on all corners after either turn signal is on over about a minute.
65gto is offline
post #7 of 7 (permalink) Old 10-30-2014, 10:29 AM
Roger that's Avatar
The original dealer installed hazard flashers (from my memory) would not continue to flash the rear tail lights if your had your brakes on.
Roger that is offline
Cig lighter hazard! Hot_Rod 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-29-2013 06:26 AM
Dukes of Hazard youtube series. batmans Audio & Video Clips 4 11-07-2009 01:52 PM
Cars That Hazard Signal A Win - With No Race?? Paul79UF Racing and Kill Forum 6 06-30-2006 05:19 PM
'04 Owners- Inspect! Fire Hazard! Groucho The Lounge 48 05-10-2006 09:38 PM
'04 GTO Rack and Pinion Leak=Fire Hazard rxdoc Service, Maintenance and Technical Discussion 9 03-09-2005 12:58 PM
