Head Casting Number Help - Pontiac GTO Forum
post #1 of 13 (permalink) Old 04-04-2011, 05:11 PM Thread Starter
Can anyone tell me if these are the correct heads for my 1968 GTO? WT 400/350 with 4-speed. Block casting number 9779001 and it does have the vin stamped on it. Correct 9790140 intake and Quadra Jet carb as well. Here is a photo. Thanks
dillon14 is offline
post #2 of 13 (permalink) Old 04-04-2011, 05:59 PM
Hey Dillon,
Unfortunately, the numbers in the photo don't really tell us anything. There should be a large 2-digit code directly on the tops of the center two exhaust ports, and a 4 character date code either on the side just below the valve cover gasket, or inside under the valve cover.
If you can get those, then they can be ID'd
post #3 of 13 (permalink) Old 04-04-2011, 06:16 PM
casting date codes
pontiac is offline
post #4 of 13 (permalink) Old 04-04-2011, 08:12 PM
68greengoat's Avatar
A visual to Bear's reply......
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 13 (permalink) Old 04-04-2011, 08:35 PM
FNG69's Avatar
My book for 68 GTO intake has # 9794234. And 9794233 for RA intake..Heads would be 9791216 (16) for 4bbl.... RAs are 31s but resembles "37".... & RAII are (96)..
FNG69 is offline
post #6 of 13 (permalink) Old 04-05-2011, 04:56 AM Thread Starter
Thanks, Will take off the valve covers today.
dillon14 is offline
post #7 of 13 (permalink) Old 04-05-2011, 08:21 AM
No need to take off the covers. The two digits are located outside, on the surface of the protruding exhaust ports (where the "7F6" is in the pic provided). If the '68 heads, there WILL be a "16" there.
Jim
Mr. P-Body is offline
post #8 of 13 (permalink) Old 04-05-2011, 09:42 AM
May want to recheck that block casting number too. I'm finding no information with that number.
It wouldn't be a 9790071? Just wondering if the numbers where not in the right order...
SOLD.....
462ci, 4spd
post #9 of 13 (permalink) Old 04-05-2011, 12:31 PM
Probably "988" (last three).
Jim
post #10 of 13 (permalink) Old 04-05-2011, 04:13 PM Thread Starter
Too late, I took the valve covers off and then saw where the two numbers were. Obscurred by paint and some rust, they are number 16 heads. And yes, I also screwed up the block casting number which should have read 9790071. I am 61 you know and run a prison having worked there for over 37 years so my mind is a little mushy. The good news is that the intake is correct 9790140, the Quadra Jet is correct 7028263, the heads are correct, the vin is on the block as well as the WT and I believe the exhaust manifolds are correct but need to remove them to get a good look at the numbers. The transmission has a casting number of 3925660 which is correct for a 68-70 Muncie Transmission but I am not sure where to look for the vin. Also wondering about the distributor but don't know where to look for that number either. Any help with these would be appreciated? Thanks.
dillon14 is offline
1964 GTO Rear axle casting number ID mike64gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 10-06-2011 09:30 PM
65 GTO casting # 65trips 1964-1974 Tempest, Lemans & GTO General Discussion 11 11-01-2010 07:46 PM
Diff casting number location DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-02-2010 10:38 AM
Casting Numbers mashype 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 05-13-2009 10:40 AM
Casting Numbers jbranontn 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 04-06-2009 08:48 PM
