Help Finding 65 389 Head Bolts (and other stuff) - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-30-2017, 09:48 PM Thread Starter
Joe Skelly's Avatar
Had to tear down my 65 389. Sat in my father in law's garage for 15+ years, without any spark plugs and without the carb covered. Nothing was covered, so I figured this would be a good idea.
Which paid off, because the crap / debris found in the cylinders would have probably damaged a lot of other mechanical inside if it would have been put together and fired.
I've searched RockAuto, Summit, and a few other sites. Problem is, they have a HUGE variety of Head bolts, but most of the descriptions state that they are for High Performance / Performer heads. I can't really find anything that says "Stock" or "OEM" heads.
Can I get your feedback about what bolts might / should work with a stock 389 block with stock heads? Or where I can get them? I don't want to get the wrong bolts, and really screw up the motor.
Also, if I can get your feedback about what kind of gaskets I should put in (Head, Valve Cover, basically all of them). I want to do this tear down and rebuild right, the first time.
Thank You!
1966 Lemans w/ 1965 GTO 389 Motor
Joe Skelly is offline
post #2 of 3 (permalink) Old 10-01-2017, 12:31 AM
The original Pontiac V8 head bolts can be removed, cleaned, & reused. This is typical practice when rebuilding Pontiac V8's. Have always put aside nice head bolts out of engine cores that heads were sold off, blocks were sold off, etc. Eventually, go through all of the headbolts & put together whatever I need. Some specific headbolts like the passenger side center exhaust studded bolt for a '66 or '67 with AC, they are tougher to find. Reproduction Pontiac headbolts are avail through the PartsPlace, but they lack the correct head markings.... something that just doesn't cut it in many restorations.
post #3 of 3 (permalink) Old 10-01-2017, 05:54 PM
look at this from E-BAY https://www.ebay.com/sch/i.html?_fro...bolts&_sacat=0
if link does not work just type in 1965 389 Pontiac bolts anDd see what pops up
Bruce Dodds is offline
65 GTO-head bolts Roqetman 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 11-07-2015 10:50 AM
Head Bolts hayes68gto 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 04-04-2013 11:10 AM
389 Head Bolts BobDole 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 08-18-2012 08:31 PM
head bolts Dan-o Service, Maintenance and Technical Discussion 16 01-09-2012 03:58 PM
Cylinder Head Bolts MaL 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 8 09-09-2010 11:10 AM
