Help finding side marker lamps - Pontiac GTO Forum
post #1 of 14 (permalink) Old 11-07-2011, 02:54 PM Thread Starter
GTO viking's Avatar
Om My -68 GTO front fender has hole cut out for some type of lamps my first thougth was Cutlass /442 fenders but hole and fender has different shape
and i cant find any in Amesperf catalog
the fender and paint is in nice condition and dont want to weld on it right now maybe in some years when striping the hole car apart and go for a total resturation.
any one has some ideas what it can be
ID:	12860   Click image for larger version
GTO viking is offline
post #2 of 14 (permalink) Old 11-07-2011, 06:18 PM
Looks like your car may have had the "cornering lamp" option. When you turned on your signal a bright light would light up on that side of the car to see curbs and such.
I'm not sure on the numbers (maybe PHS does though) but you don't see them very often.
post #3 of 14 (permalink) Old 11-08-2011, 02:39 AM Thread Starter
GTO viking's Avatar
it not have cornering lamp option on PHS doc what i can see, maybe front fenders has been replaced.
is the cornering lamp availible at any store i cant find them at Yearone or Amesperf.
post #4 of 14 (permalink) Old 11-08-2011, 10:30 AM
I agree, it looks like a fender for cornering lamp. If I remember correctly a Grand Prix uses the same cornering lamp, maybe other Pontiac as well. If I had to guess that will be a hard part to find. I have seen them come up for sale on ebay before. Good luck
68raGTOp is offline
post #5 of 14 (permalink) Old 11-08-2011, 11:21 AM
68greengoat's Avatar
Looks to me someone added those cornering lamps. Early '68 GTOs had cornering lamps. But, it was just an extra bulb in the turn signal assembly. Later '68 GTOs only had one bulb. Not sure what month of the transition.
EDIT: After further reasearch, I came up with this. Like the OP, I don't see anything in the PHS doc where it was a GTO option. Read below the pic:
GTO Links, Wallpaper, Screen Savers and GIFs
Saw this too:
Supermarket Nirvana: 1966 GTO Wagon - Daddy Types
Here's the story of the wagon...
1968 Pontiac GTO Wagon - High Performance Pontiac Magazine
The one/two bulb signal assembly info is correct. I have two...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #6 of 14 (permalink) Old 11-08-2011, 12:21 PM Thread Starter
GTO viking's Avatar
build date is 15 of april 1968,
I will look at ebay if something is coming there i have all winter to search for them and last resort it to put on my other fenders that i have in store but they are not painted yet
one other funny thing is on PHS on option 34 engine i have a 5 and options is 1,2,3,4,6,8
post #7 of 14 (permalink) Old 11-08-2011, 12:49 PM
EDIT: Even tho I still don't see cornering lamps in the PHS doc, I see them as an option in another manual that I have. It is option code 651. No idea why it's not listed in PHS.
Given your build date, you probably have 2 bulbs. You may be able to see them thru the lense, or, just pull the lense and see if you have 2 bulbs/sockets.
What did they hi-lite for your engine option if anything as 5, like you said, is not an option?
SOLD.....
462ci, 4spd
post #8 of 14 (permalink) Old 11-08-2011, 01:10 PM Thread Starter
GTO viking's Avatar
I dont have any part for cornering lamps and i cant see any cables for them ,the lamp socket that are showing on picture is for front parking light
I will try to keep this cornering lamps even if it not right option for my car I about to put power windows in also and that is not on my option list but a nice thing to have on a convertible car.
every other thing it marked with yellow marker but not engine.
post #9 of 14 (permalink) Old 11-09-2011, 02:23 PM
PM me, have some 68 cornering lamps that might fit. Measure your openings so I can check mine.
pontiac is offline
post #10 of 14 (permalink) Old 11-09-2011, 07:18 PM
The 5 in column 34 is the standard 400 4bbl. The 1,2,3 and 4 do not apply to a GTO. The 6 is the economy 400 2 bbl. and the 8 is for the RA option. As you said those numbers are options.
68raGTOp is offline
Monaro side marker lights blackguppy Exterior Discussions 1 12-24-2007 03:31 PM
clear side marker lenses StaleyCornell Exterior Discussions 2 02-22-2007 08:28 PM
monaro side marker lights... Holden1984 Service, Maintenance and Technical Discussion 1 02-16-2007 11:58 AM
