Help identify this part!!! - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-04-2011, 07:05 PM Thread Starter
DaleGolds's Avatar
I have my 65 GTO completely torn apart restoring it piece by piece. I am normally very good at bagging and tagging items so I can remember what they are, except this piece. I went to get some of the smaller items out so I can clean them up and repaint them. This bracket was in a bag with the retaining ring that holds the clutch rod boot to the firewall and the semi-circle bracket that bolts to the bottom of the dash and holds the steering column in place. So I know it is from under the dash, on the dash, the firewall, or the steering column. It is definitely designed to hold something in place because of the wedge sides and it only has one mounting hole. The arms are also different lengths and notched differently. If you know what this piece is and where it goes I would appreciate your help.
Thanks,
Dale
ID:	11031   Click image for larger version
ID:	11032   Click image for larger version
ID:	11033   Click image for larger version
DaleGolds is offline
post #2 of 4 (permalink) Old 05-04-2011, 08:28 PM
crustysack's Avatar
that is the bracket that holds the steering shaft cover in place.see pic- it goes under the shaft and has a stud that threads into the shaft cover. the bracket sits against the dash and when you turn the stud it tightens the cover piece into place, and there is a lock nut to stop it from backing out
Name:	iphone pics 015 mod.JPG
crustysack is offline
post #3 of 4 (permalink) Old 05-04-2011, 10:21 PM
FNG69's Avatar
Here is a picture of the parts all together..Les
Uploaded with ImageShack.us
FNG69 is offline
post #4 of 4 (permalink) Old 05-05-2011, 08:44 AM Thread Starter
DaleGolds's Avatar
Thanks for all the help. I guess I am going to have to wait until I get my steering column back and install it before it clicks and I remember the part and taking it off. The mind is a terrible thing.
can anyone identify these wheels? busaben 1964-1974 Tempest, Lemans & GTO Wheels & Tires 7 03-07-2011 07:16 AM
Identify - Location - Purpose of part. ChromeShopJoe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 08-13-2009 01:12 PM
Can You Identify This Car? GTO JUDGE The Lounge 17 06-18-2008 08:09 AM
Help Identify Interior Seats A_New_Creation 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 10-09-2007 07:43 PM
Identify Giant HOLE in 05 GTO?? ShadesOfGrey Service, Maintenance and Technical Discussion 5 10-11-2005 01:09 PM
